REAL MILK PAINT
Pendant construction
Here is a really brief description. First I mount the wood to a 2" square block using cloth backed double stick tape. remove 2 jaws from the chuck so you can shift the block.
Then I turn it round and round over the side near the waste block. This was a really punky piece of wood so I didn't bother trying to get a clean cut. It's going in the garbage.
The I tilt the block out to create a wedge shape after turning. At this stage you can turn some details if you want. or round over the fat edge.
Then I shift it straight up in the jaws and bore a hole. I usually shift it up, turn on the lathe and mark the center. Then draw a larger circle with the lathe off rotating by hand to see where everything will be and how big to make it. If it's not right readjust. Then I bore the whole with a detail gouge. I round off the bottom of the hole and the top side.
That's the basic pendant. You can shift it any way you want in the chuck to create other details. It challenges your skill because only a small part of the wood is actually touching the tool at any given time. If you don't feel very skilled lay a skew down on it's side and make little V cuts here and there as you shift the block to learn more about how it works.
Re: Pendant construction
phillip Medghalchi
John, thank yo very much for posting this pictorial explanation.
cranskin
Thanks for the photos of the whole procedure. Will have to give it a try.
Dave Crady
Thanks John for sharing the photos. Much easier to visualize the process.
