Compass Rose for Segmented Bowl bases
Blondterror
Anyone make any bowls with compass roses in the base... I plan to build a few with these using mahogany around the CR and then figured maple layers
Made up a simple TS sled with toggle clamp to get the 22.5 degree cuts
Re: Compass Rose for Segmented Bowl bases
gary clarke
Very nice design. I am worried about the difference in wood expansion at the center which might cause eventual separation at the point. Let us know how it works out after several seasons of expansion and contraction.
Craig Daymon
Looks nice. Not sure it will help, but I believe Dave Hardy did an article in American Woodturner many, many years ago that may prove helpful. He was including similar designs in Christmas ornaments.
I have a memory of the article and remember it being in black and white. (Or ebony and holly in woodworking terms. :b )
If you are an AAW member, a search of the archives should bring up the article.
If you're not, consider joining. It is well worth it.
Not being a segmented turner..
... how do you cut the mahogany or whatever will surround those things? I guess that if you can cut the pieces for the rose, the flanking pieces would be a piece of cake, though I suspect that if it were I doing it, there might be some specialty tune up work.
Please do report back on progress.
Re: Not being a segmented turner..
Blondterror
I fill in the points with triangles that have a 90 angle that nestles in and glue/clamp an opposite pair at a time. Then I trim the long side of the triangle to be exactly flush with the rose points. Then I add the 8 sided segments so no end grain is seen from the outside of the bowl.
Some trial and error miter cutting is sometimes needed to fit the triangle pieces.
phillip Medghalchi
I am sorry, but the compass rose is higher or has thickness to it or is it a design you will put on another substrate? The picture with that granite won't let me see exactly the depth of your rose. And also, as Valentine asked. how do you then put this in another piece to make the bottom of the bowl? Maybe more picture of the process will help us out. Thanks, for sharing, I am sure it would be a great looking bowl.
Blondterror
Yes the compass rose layer is 7/8" tick and will be added to a base layer which I chuck in my big Vicmarc on my Vega bowl lathe.
I am finishing the the compass rose layer glueup this morning and will post a picture later today. A labor of love to incorporate this into a bowl bottom...
Blondterror
This picture should explain how the compass rose layer will be incorporated into my segmented bowl. To date all of my segmented bowls have been 12 sided and I made the sled for the 15 degree angle... now I need to make an 8 sided sled with the corresponding 22.5 degree cut angle
I center the CR using a small hole on the bottom and the base substrate and use a piece of toothpick as my orientation post during the glueup in my shop made press
Blondterror
here is the finished blank for the 14" by 5" segmented bowl with the compass rose base. The "rose" is embedded in mahogany , the rest of the layers are highly figured maple with the exception of the top thinner layer (.5") with is also mahogany.
The other blank is a 9" diameter maple/walnut blank.
That's Gonna Be NIIICE!
Re: That's Gonna Be NIIICE!
Blondterror
Not sure that I posted a pic of the finished bowl and this addition set of bowls. I am really enjoying building these bowls although them do takea lot of prep work in the extensive glueup stage
Chris
Ron Bauer
Chris, Truly beautiful. Do you find the individual bowls to be stable at the glue line between the segmented rim and the solid body vis-a-vis differential movement? I am awed by the patience in these pieces. Ron.
Blondterror
Ron-- I do not have a large data set for the segmented rim bowls that are mounted on the solid body... I have turned about 20 of this type and through 2 years they are still looking good but time will tell..
Chris Groves
Ron Bauer
Thanks, Chris. I gotta believe that two years of exposure would tell the tale. Again, great job.
