Drum Stick Info.
Drum Stick Info.
Drum Stick Info.
Tom Minehan
My 10 yr. old Grandson has decided to become a drummer and I would like to turn him a set of drum sticks. I know nothing about them and I am looking for information from you drummers.
I presume they should be made of some type of straight grained hardwood but is some type preferred? I also wonder how much the length and diameter matter in relation to arm length and hand size. I notice that some sticks seem to have a round ball on the end while others have an oval. Does it make any difference?
Thanks for any help you can give!
Re: Drum Stick Info.
robo hippy
A lot of them used to be made out of sugar maple. I think a lot of them are now made out of hickory because it takes the shock loads better. Some have plastic tips, some wood. I had a jazz drummer ask for some out of cherry because it gave a little softer sound. I think preference is like in woodturning, every one does it different. You could just copy some if he already has some.
robo hippy
Don Leydens
Don Leydens
Hi Tom!
Like Robo said, if at all possible buy a set of sticks and copy them. But first, find out what style of drumming your Grandson plays. Jazz drummers lean towards a lighter, thinner set of sticks where a drum major in a HS band might use much heavier, fatter sticks. Rock could be somewhere in the middle. Length is also important.
Woods vary, but straight-grained hickory is a good choice. The tip shapes are also important. Some are almost round while others are quite elliptical, even pointy.
Also, a super slick, buffed finish isn't a good thing in this case as the sticks can get sweaty and slide right out of the players hand. Personally, a good, even sanding to 180 and one light coat of oil would be fine.
Hope this helped more than confused, Don
