Re: TWICE TURNED BOWL By Reed Grey
robo hippy
Well, the easiest way to answer this one would be to have you in the shop for a day or so. It is a question you could write a book about. I am still getting clips up of footage I shot for a video that I am going to just put up on You Tube. I had 8 hours worth of edited footage.
Most of the time, I have the tool rest at center height, +/- a little. In this clip, with the twice turned bowl, you do not have clear access to the bottom of the bowl, and still have to turn some off. This is why I drop the handle, roll the tool over on the side, and do what is called a shear scrape. It gets you into a narrow spot and allows you to cut. You can't rub the bevel in there, and this works, even if it is much slower than turning the outside to finish before you reverse the bowl to do the inside.
There are 2 basic cuts, a bevel rubbing cut shear cut, and a scraping cut. There is a hybrid cut called a 'shear scrape' which to me is not a scraping cut at all. So....
Shear (I first thought like wind shear where inside the thermal the wind goes up, and outside the wind is going down or the other direction), or Sheer (as in the sheer face of a cliff) as Lyle says, refers to the angle of the cutting edge to the wood as it spins. If your scraper is flat on the tool rest, the cutting edge is 90 degrees to the rotation this is a pure scrape. There is no shear at all in this cut. It is very coarse, except when turning end grain where it works very well. A higher shear angle makes for a cleaner cut. I compare it to driving over speed bumps in the parking lots. If you hit them square on (scraping cut) it can be a pretty big jolt/bump. If you hit it at a 45 degree angle, you get a much smaller bump. If you hit it at a 70 degree angle, it smooths out still more. So what this means is that the higher the shear angle, the more gently the cutting edge slips in under the wood fibers and lifts them off.
Scraping cuts can be done with scrapers and gouges. This is all about how the cutting edge enters the wood. At 90 degrees, a pure scrape. With a gouge, you hold the handle level, roll the flutes over on the side (3 or 9 o'clock) and cut (safety note here, if you hold the handle/tool level, roll the tool all the way over before putting it into the wood. If you roll it over rubbing the bevel, then roll it over more till it cuts, the point where you come off the bevel, there is no tool support and it will dig in very quickly). You do not rub the bevel, and these cuts are best for heavy stock removal. A scraping cut is a cut, I can get nice long ribbons of shavings when doing this, but it does leave a rather coarse surface.
Bevel rubbing cuts are probably the best finish cuts, and can be used for roughing, but I don't find them to be nearly as efficient as a scraper. With the curved shape of the flutes, there are a lot of different ways to rub the bevel. Most of the time I hold my gouges more level, and roll the flutes over at least 45 degrees away from the cut. The nose is doing a nice 45 or so degree shear cut, and the wing is doing more of a scraping cut. You can increase the shear angle some by dropping the handle. This also makes the wing do more of a shear cut. This is some times done with the bevel on the wing rubbing. If you drop and roll enough, the wing can get in a 60 degree or so angle shear cut. With the fluteless gouge, you can easily roll to 70 or 80 degrees. Most of the time this works better for very soft or very stringy woods, while the standard 45 degree shear angle works for most other normal woods. This is generally a final cut. If you leave the flutes pointing straight up, there is a tendency to catch or try to cut with the inside wing (one closest to the wood you are cutting) and the tool will roll over into the wood/catch.
The shear scrape is a hybrid cut. This is generally used to clean up tool marks and all those little bumps and humps for when your other tools are not working like they should. Again, this is a high angle shear cut, but you don't rub the bevel. With a gouge, you drop the handle, and roll the flutes over, do not rub the bevel. Some times this almost has your flutes upside down. It is a clean up cut only, and not for heavy stock removal. It will take several passes to even things out. I prefer a swept back scraper for this. Same idea, burr on the edge, drop the handle, and no bevel rub. Multiple passes for clean up. The advantage over a gouge in this case is that you can see the edge as it cuts where with a gouge, it is rolled over to the point where the view is obscured. On the inside of the bowl, you can do the same thing, but I prefer a scraper with a ) shape nose or very little sweep. Drop the handle (this has the added benefit here of making it impossible to cut with the high side of the cutting edge and getting a catch), and gentle pull cuts up towards the rim using only the lower part of the tool. Great for blending in the stop/start marks the gouge leaves. This cut is mostly used for little clean up things that you could sand out, but who wants to sand when you can cut it out. I also find this cut handy if I want a perfectly round bowl, as it will take out that tiny +/- 32nd of an inch or so of bounce that you always get. Not critical unless you are making a bowl less than 1/8 inch thick.
Now, the finished surface, bevel cut or shear scrape? Of course, it depends on a lot of things. One point Jimmy Clewes makes is that he doesn't really like a bevel rubbed finish. His explanation bought back memories of doing flat work where you never took it beyond 220 grit before finishing. The reason was the higher grits would actually burnish the surface, and the finish wouldn't penetrate or adhere because the surface needs a bit of coarseness. Jimmy said he likes a shear scraped finish because a bevel rubbed finish, because it is burnished, requires you to sand through the burnishing before the abrasives really start to cut. Well, for sure this is true with some of those little lines you see from when you are rubbing too hard, or stop/start a cut. The thing is that a bevel rubbing cut usually leaves the cleanest/least amount of tear out surface when compared to other cuts. Some times a shear scrape, no matter which version you use will rough things up rather than smooth them out. Most of the time this involves really punky wood or some that tend to be really stringy. Some times the shear scrape really is an advantage. It depends on the wood. Well, a sharp tool as well.
Oh yea, I have a brother in law who is a 'Grey'. We tease him unmercifully at family functions. I am a Gray. No offence at all.
robo hippy
