How do you lock your faceplate?
Geoff Whaling
Wally,
I'm more interested in how you lock your faceplate while turning in reverse & hollowing?
With modern lathes I can really see no reason why they can't be used in LH or RH mode other than the safety aspect of unscrewing accessories from the headstock spindle. So most curious how you solve that issue. As a rightie doing a lot of small spindle stuff I've often reckoned lathes are built wrong.
John,
I use glue blocks a lot and in combination with faceplates or chucks. Just depends upon the application. As for cutting into screws - why would you want to do that? ;-) Screws shouldn't go past the waste block & your planning should have allowed for removing waste from the block for access to the main piece without going near the screws.
