While I was in egg production, I found a pile of cedar that was laying in the snow all winter. Power company buchering the trees. I did not need any more wood but I got 2 truck loads. I cut and turned this bowl. It's 8 inch by 8 inch at the the tallest sides by 3/8 inch thick. It was dried in a microwave. It's been oiled twice then buffed with the Beal system. I did not wax it. Waiting to see how long before the color fades. and what it will look like.
I think you need to remount it on the lathe to clean up some of the torn end grain on the outer edge of the bowl. The inside looks pretty clean, but all I see on the outside is that plucked end grain. I would make a padded disk for the bowl to sit over, and another padded disk for the tail stock and then resand with the lathe running very slowly.
Your inside and outside surface should be the same. It makes the piece lose something when you did such a good job on the inside.
you have a 5" random orbit sander. If you don't, that Harbor Freight sander will loudly do the job for little money. It's around $25. I bought one because the dust collector attachment is really small. It lets me sand the inside of large bowls if I remove it. Best done outside with a fan running next to you, but they work great. Just resand the outside and refinish.
I saw the tear out after I took the picture in the day light. I planed on sanding more already. I am waiting a bit to see if the bowl loses it's color. Yes I took your sugestion as it was intended. An yes I have a 5 in sander.
It might be a better idea to sand right away. As the wood oxidizes and changes color your sanding might reveal fresh colored wood and give a blotchy look, some sanded, some not sanded as deeply.
Dan, here is my Piece that I put it on here some while ago. Here is what will happen. since that wood is wet it will start splitting and small cracks will show, but don't fret. Just let it sit and it will close up (most of it). Try to put that piece some where that ther no distraction back ground and then take a better pic. of it as that would be the only memory you will have of it being that beautiful purple color.
Now, as you can see in these pic.s I was warned that this piece will not work because I did and end grain. tomorrow I try to add the current pic.s of it for you to see how much the color has hanged.
Now, for the finishing, it is important that you clean it very good as matter of fact few times with lacquer thinner and try to get all of it's oils out of the inside and the out. Do not handle anything else that you may transfer some oil on it. and make sure your hands are clean before yo apply your finish on it. I put lacquer sanding sealer on it and evidently I mishandled it and had some oily spots on it and even though that I tried to sand it back down I still didn't get all the oil out of it. If you apply your finish and then end up having a spot that it will not take finish, then go back and sand it again and this time cover it with some shellac and build it up then come back and your put your finish on it.
As for your cracks, I put some thin CA in it and try to leave it alone w/o spraying it with accelerator. Hope this will help.
I was in a hurry, to show the bowl and to finish it. So I have taken a step back, I resanded the bowl and I am building coating on the bowl. When it is done ( again) I will take a better photo. Thanks to all for you guidence.
Thank you for the picture, it looks very, very nice.
Well the reworked bowl is getting closer to being finished. I sanded the bowl completely down starting at 100 grit to 400 grit. Stopping in between to clean the bowl and checking for problem areas. Where there was major tear out areas I just sanded with a 2 inch disk sander on a soft pad. I then coated the bowl with thinned down lacquer ( 70/30). I dried it overnight before I put on another coat. I then used 2 coats of not thinned down Lacquer. It might have been too cold or my Lacquer is getting old but I got a lot of brush marks. Right now the bowl is sanded down at 400 grit. It’s waiting for me to setup the buffing system to finish.
I, for one, have never had much success with lacquer, especially when brushing it. I'm sure there must be a way, but I just haven't found it and don't have the patience for it. I'm a much happier camper since I discovered Minwax Wipe-on Poly, Satin. I usually sand a piece to 400 or 600, then apply WOP, almost wiping the piece dry, and let it dry for 24 hrs. I usually apply 3-4 coats this way, de-nibbing between coats by lightly hand sanding with 600. I let the final coat dry for at least 48 hours before trying to buff. I usually use a little white diamond during buffing and have had excellent results in getting incredible finishes. I also believe that the WOP impedes the color change that wood like cedar and Box elder normally go through. I have pieces of both that are several years old and are nearly just as bright as when I turned them. Just my $0.02. So if your piece doesn't turn out as good as you would like, give the WOP a try. It's a lot easier than lacquer.
