I'm new to turning, but have worked with wood since I was 10 or 11 yrs old. I know the value of keeping tool sharp. I have a powertech low speed grinder with 60 & 120 grit white ox wheels. when should i dress the wheels. my best guess would be when the tool I'm shaping builds up heat/ starts turning blue.
I dress them a lot. Right out of the box to true them, then if I see any misshapen face or much black at all. The black is steel particles stuck between the grit. That builds friction and heat. If you dress quite a bit, you remove very little material. Wait too long, and you have to take off at least 1/16" to make them flat.
Well, I cheat and use the CBN wheels which don't ever need dressing. With standard wheels, it is easiest to tell if you are using white wheels. If they are black with metal build up, you are very late. If they are grey, probably time to touch them up. The cleaner they are, the cooler they cut. One problem with heat building up and bluing is a lot of the time it is because of too much pressure when sharpening. Properly done, you just brush the bevel against the wheel, and don't push into it. This also reduces the number of times you need to clean your wheels.
Don't forget as you dress the wheel multiple times the wheel is getting smaller. We need to move the grinding jig sliding arm in after a while to keep the grind angles correct.
Phil, I would use the pink dress, I've lost the matching shoes and purse in the wood shaving, and my wheel would never be happy unless the whole outfit matched
Reed, in that case based on that condition can I change my request to a dedicated shop instead. (They said I was good people,, not me ) You have to have some kind of Taxation venue to not give Uncle Sam bulk of your money.
Mike, I hope you have some kind of real metal (to pick them off with magnet) in any of those items, because you are not gonna find them that easy down on your knees and digging through the shavings, unless you worked on a Walnut piece (dark brownish color)
While looking for the house and shop I now have, I saw the 'perfect' place in the paper. 1800 feet of river frontage. 27 acres. Bass pond. Year round stream. 3 houses. Multiple out buildings. And the kicker, a 10,000 sq. ft. shop. They did not list a price, and I didn't win the lottery that week end either.... Heavy sigh!
