How to determine size of stand for glass vase
Mark Hoffman
How do I determine the correct size for a turned wooden base for a glass vase that is 3" diameter at the base, 7" diameter at the widest point and 11" tall?
Mark Hoffman
Re: How to determine size of stand for glass vase
John Veerkamp
Is this a stand for the floor or for a table top?.. Either way you want the base to be proportional to the top and the item being showcased. You don't want to overpower the vase with the stand, but it should be stable enough to protect the vase.
Mark Hoffman
Table top stand. The stand is to be a turned piece of wood which the vase will sit on.
Thank you!
Bill Howatt
I don't think it is a simple case of making the base some multiplier of the top or whatever.
It has to blend, not over-power, as was said. If the vase has a curve then the base should most likely be a continuation of the curve. However there will be some vase shapes that this will not apply.
This is a case where some pre-turning sketching can be a big help and will save some trees. The dimensions are suitable for doing full-scale sketches. You could also Google "vases" and maybe get some ideas about what can be done for the base of a vase - the potters have been shaping things for a long time.
Bill
Mark Hoffman
Your helpful comments make sense and thank you for that! Your comment that they flow together is right on. Thanks again!
