grinder choice
OK these are just my thoughts on the subject based on 35 years of grinding and sharpening. I think we sometimes scare off new turners by telling them they need a fancy grinder with really expensive wheels, in some cased probably more expensive than the lathe they bought.
I sharpened for years on a very old Craftsman 3450 1/2hp grinder with gray wheels. Granted it wasn't perfect but I did a lot of turning and turned out some good projects.
I think what is important is a grinder that spins true and balancing and trueing up the wheels so everything runs smooth. It doesn't have to be expensive. I can buy a Harbour Frieght $39 grinder and put some inexpensive white wheels on it from Enco and have a good grinder. Maybe $50 to $60 invested. Speed of the grinder isn't important and your only going to be removing light passes on the metal so even a 1/2 horse is enough.
With a good tool rest and/or some good sharpening jigs added you can do a very good job of sharpening lathe tools.
Now I certainly won't argue that a Baldor 1725rpm grinder with a CBN wheel would be a better choice. Probably run you about $500 or more. Obviously the better grinder and better wheels you can afford the easier sharpening will be.
I think most people will say that the slow speed grinders sold by Woodcraft with a set of white wheels would make a very good investment for new turners. You do need to check to see if it runs smooth and then take some time to balance the wheels and make them run true. After that you have a good machine and is the one I have used for the last 12 years although I did add the CBN wheel recently.
Anyway those are my thoughts and probably worth the 2cents you get when you ask me a question.
A nickles worth now that's a whole new ball game.
