Band saw blades: hook or alternate?
Sergio
Hello, I have been using only Lenox flex back blades with Hook tooth on my 20inch band saw for cutting blanks green and dry.
In your experience are the Alternate tooth a better alternative?
I generally use 1/2 and 3/4 inch blades.
Thanks.
Re: Band saw blades: hook or alternate?
Chuck Engstrom
Hi Sergio -- I have been using Timberwolf 3/8-3AS blades (AS is alternate set for wider kerf in green wood, as I understand it) for some years now and find them very satisfactory. They're intended principally for green wood but of course will cut dry stuff too, though leaving a rougher cut than possible with other blades. I have them on a Delta 14" with riser and 1-1/2hp motor and get them from Suffolk Machinery on Long Island, cheaper than buying them at Woodcraft.
Others here will surely give you other suggestions which will be no doubt worth looking into.
Best regards --
Chuck
Steven Antonucci
Just looked at mine
steven antonucci
It looks like a hook blade with alternating teeth? I cut mostly green wood, and occasionally dimension dry wood with it. I think the same blade has been on the saw now for almost 2 years? It is a Timberwolf blade, and I buy it via Woodcraft because they are the only place I have found 142" blades.
S
robo hippy
I have been using the Lennox Diemaster bimetal blades for years. They just cut better than anything else out there. Not sure about the flex back ones. I have a dealer in town who makes up what I need. I like the thicker ones (.035 I think), 1/2 inch and 3 tpi for my little saw, and for resawing bowl blanks (Laguna 16HD), a 1 1/4 inch blade with teeth about 3/4 inch apart. If you are purchasing locally, ask the maker.
I have had a couple of people who used the Timberwolf blades try the Lennox, and they all switched.
robo hippy
Dick Coers
Alternate grind is for smoother cuts isn't it? Hook tooth for me since I don't care about the cut quality when breaking down turning blanks.
Josh bowman
I've had great luck with Highland hardwares woodturners blade.
Sergio
Robo, that type of blade is very expensive.
I tried before the Timberwolf but I was not satisfied. The Lenox carbon flex back Hook tooth worked fine so far but just wanted to have inputs on the Alternate tooth that I've never tried.
Thanks.
George Balock
George Balock
I think the hook tooth is more aggressive than the alternate. I use the Timberwolf 3AS and have been satisfied. The biggest issue in cutting green wood is can the blade clear the kerf of sawdust. The 3AS does this well. If a smooth cout on dry wood is what you are after, you need a finer tooth. I've thought of changing to a carbide, but the price tag is too high.
I also like Timberwolf 3 AS
Harry Robinette
Re: I also like Timberwolf 3 AS
Harry Robinette
I like a skip tooth it gives you more gullet to get rid of the saw dust usually a 142" 3/8 x 3 to 5 tpi skip tooth.
I was getting them from a guy who made blades, but he past away this last year.
