Quick question on Oneway rotary adaptor
Sergio
Hi, I just would like to know which is the size of the barbed tube connector of the Oneway rotary vacuum adaptor. Does it fit a 1/4 or 3/8 ID tubing?
Thanks.
Re: Quick question on Oneway rotary adaptor
Mike Brazeau
Interesting that Oneway do not include that measurement in the instructions. Just checked mine and I have reinforced vinyl tubing on it that is 5/8" OD and walls look close to 1/8" so I would say 3/8".
Sergio
Thank you.
ron bauer
Sergio, I hesitate to state the obvious, but will do it anyway. Make sure you get hard wall tubing or else it may collapse under the vacuum. Just ask to make sure it is suitable for vacuum use. You will probably be pulling around -20" Hg if all is working properly.
Bill Howatt
I have been using the tubing they sell for water systems - fairly thick-wall, clear plastic with a loose fiber-glass(?) braid running through it.
Although I don't have a measurement, I also believe it is 3/8"ID tubing for my Oneway adapter.
Bill
Sergio
Thank you again.
Jorge
Sergio,
I got mine in a place that sells components for hydraulics systems.
It is see thru with a reinforcing weave on the midle of the wall.
