this is how I unload my logs, don't you *LINK*
https://www.youtube.com/watch?v=TtEFvIzo1OE
Re: this is how I unload my logs, don't you *LINK*
I've done similar.
robo hippy
Well, I once had a chunk of myrtle in the back of my van, loaded in with a fork lift. I had to drive a couple of steel stakes into the gravel and tie a chain around it, then drive out from under. Kind of like that....
robo hippy
Reed I have done that. They cut down some trees on campus and loaded them into my truck with a fork lift. I couldn't even slide them on the plastic bedliner. I wrapped a chain around a post in my garage and dragged them off the truck. Then used a long pry bar to roll them into a pile.
Dale Gillaspy
Done that as well. I had some very large Mesquite that I had to tie a logging chain around and drive out from under
Dick Hines
Dick Hines
Getting logs out of pickup like that can be real hard on the tail gate
Bernie Rose
I pulled a strapped stack of RR ties off my truck like that, and then I went and bought a new tail gate !!!
The next time I took the tail gate off first. The high cost of tuition !
Re: How should you unload
Stuart Johnson
a log or rr ties without damage?
If you've got a tailgate your not redneck enough
Re: If you've got a tailgate your not redneck enou
Bernie Rose
Got to have a tailgate to hold the McDonalds trash until the wind blows it into the ditch.
phillip Medghalchi
John,, this was a good one. Only happens in far east I guess. I wonder what the driver told the boss happened to the drive shaft?
Sergio
It shows a good knowledge of physics.
RCH
Hardly only in the far east. I've seen it done elsewhere.
Steven Antonucci
Someone here warned me about the tailgate...
steven antonucci
So I removed it before pulling the truck out from under a 30" oak crotch. Heavy strap and a tree, but it actually broke the asphalt in the driveway...
S
Re: Someone here warned me about the tailgate...
phillip Medghalchi
Only guys with lots of money do this?
you have an asphalt driveway  mines grassel
