200+ woodworking book reviews
shop done for now
shop done for now
shop done for now
I finally reached a point where every horizontal surface had piles on it and I had to suck in my stomach just to get around machines. Totally rediculous. I know my shop is too small but I do the best I can. I spent the last month when I wasn't traveling trying to redo the shop. Installed 220 ones so I could get the new machines in. Sold the old ones (except for the Delta drill press which is sold but still here). Bought 2 parts bins and cabinet that I use for parts + another tool cabinet.
I did away with the carving bench and moved it to the backside of the table saw to become an outfeed table. It will still be a carving bench but since it's the outfeed table I won't put stuff all over it like I did before.
Still need to figure out what to do with all the wood. Buying a shed is out right now for the near future. I'm thinking about buying a small farm that has one of those 100 yard long chicken houses. I think I could get my shop in one of those.
Here is a view of the central part of the shop showing the new bandsaw and how crowded things are. I don't put long things through the drum sander so it might work quite well where it is. Moving the dust collector toward the middle of the room actually gave me room to run full length boards through the planer and it's much easier to remove the bags.
I bought another small tool cabinet and put the Tormek and sander sharpener on that and was able to clean up some of the overcrowded drawers in the lathe tool cabinet. Still need to build my sanding cabinet. That piece of #$%$ plastic thing that I bought was a waste of money. this is my lathe wall
Looking in from the right hand garage door. My new air compressor is on the left (you can just see the edge) Disc sander and Drum sander flank the sliding miter saw. The open area is of course where the motorcycle sits most of the time. Believe it or not I can work around it pretty well. I keep a cover on it.
This looks at my workbench from the lathe area. Still kind of a mess there but better than it was.
Re: shop done for now
This is the bad wall. Everything on the back wall will be rearranged sometime this summer when I have time to build cabinets. The parts cabinets and paint storage cabinet will go against this wall which should open up the middle space more but have to figure out what to do with all the stuff. worry about that later.
Here is the south wall showing the metal lathe and new metal drill press. I actually have dust collection at my drill press now for the first time.
Well that's a quick tour. Plan to do a lot of turning for the next 3 months or so and will try to plan the reorganization of the back wall during that period. Maybe I'll get lucky and win the lottery and simply buy a new shop in a new location.
Steve Criscenzo
Looking good John. Only thing I see missing is saw dust and wood chips. Way too clean. Is it possible to build a lean to type addition to the outside back wall to store wood and maybe the dust collector.
Steve
John lucas
Considering that option but don't want to put much money I. It since I may be moving I. The. Ext year or so
phillip Medghalchi
John, in pic. 3 you have your steady rest and I was going to ask you if you could send a pic. of the bottom plate and how it goes into the bed ways. I had a friend made me a 20" Dia. steady rest and he hasn't made me the plate to lock the steady to the bed ways. My problem is that I got the legs for my lathe form afriend which much sturdier than what you can buy from Nova, therefore, i had to mount it on top of a 2.5" Walnut slab so, my lathe doesn't have the back side open I have about 14"wide table top behind the bed ways from me. I had my fiend make 4 arms which hold 4 wheels and on arm will hit the table in the back. Also, i think I have to cut the back side of the table form me and hinge it to the main table so when I am using the steady rest I can drop it, so the bottom arm away from me can sit in the right place, however, I wanted to see how the bottom plate on the steady rest is located. I wanted to be able to drop the bottom plate between the bed ways instead of sliding it form the end of the ways form tail stock side and need to figure out how to lock the plate and the steady in place if the bottom plate need to lock under the bed ways while I an drop it in form the top. I try to take pic. tomorrow sometimes so all of this will make sense. i appreciate if you could attach a pic. of it.
Just got that steady rest this summer. A gentleman passed away and no one else wanted it so I bought it. It weights 87lbs. It's all I can do to get it up on the lathe. The locking plate was missing and I haven't had time to build it yet. I'm going to make it slightly narrower than the gap in my bed and longer by 2" with rabbits cut in both ends. This way I can turn it sideways, set the whole thing on the bed, then twist it and lock it in place. I'm doing it that way mostly to save on the cost of the steel.
I have a smaller wooden version that I use for most things that need one and it's wooden locking plate is larger and I install it by reaching up from the bottom which you say you can't do.
Bill McWhirter
John, is that a propane cylinder in the lathe picture or is it part of a vacuum chuck system?
Ron Solfest
Thanks for the pics John. You made me feel my shop is very spacious, if a little under-tooled :)
That's the explosive materials I use to hollow my vessels. It's a 100lb propane tank that I use to heat with. I have plans to build a small attachment to the garage so it will be outside but that's on the back burner It's not really too much in the way so it sits by the door. Just one of the many things that still need to be done.
Don Wilcut
Sure looks different from a few years ago when it was in your basement/celler.
Boy that's for sure. I remember asking the owner if he minded if I did wood working in the basement. He said sure. About 2 years later he came buy one day and actually saw the shop. He said, man you really do a lot of woodworking down here.
Looks Good John!
Don Orr
You sure pack a lot of function into a limited space.
Re: Looks Good John!
Jim Scarsella
Great space! Now all you need are some tools :)
oh boy  Jim said I could buy more tools.
Steven Antonucci
organized but a lot of stuff...
steven antonucci
I gave up on the "everything instantly on" model in my shop, and opted for "everything rolls into the one open space" model instead. You probably have to walk 2 miles per day up and down the pathways...I am too old for that!
Someday, I will win the lottery and build a shop where everything lands somewhere perfectly and it isn't pieced together from 1000 ideas and dumpster dives...until then, I'm in 14x26".
Steve
Re: organized but a lot of stuff...
Steve I don't mind walking. In fact somethings cause me to walk around the circle. It burns calories and keeps me young.
Jennifer Indy.USA
John, it looks great!
Retirement is looking good!
Bart Leetch
At first I didn't look to see who started this thread I read the 1st post & looked at the pictures & thought this has got to be John Lucas so I went up to the top & sure enough it was John Lucas.
I agree John A renovated chicken coop is in order. In fact I was looking at one yesterday morning while waiting across the road for the DAV van its probably over 200' long & about 24' wide. The LOML & I were talking about it as we waited how it could be divided up into storage & or small shops for others & rented out with a substantial area left over for the owners shop.
Check out those chicken coups......
JamieDonaldson
... very closely, as some are not very tall, and you don't want to have the old guy problem of bending over to work or raising the roof. A turkey coup might be a bit taller, and pouring a concrete slab might make the roof even lower, but the floor will then smell better! :D
Don Leydens
Don Leydens
Congrats on your progress, John. Now THAT'S a shop!!
Very jelous
Jorge
a clean shop! and you have that end mill machine...
