Have a question? Ask Woody!
Looking for screw chuck
Gary Smyth
Somehow I lost my screw chuck. 1 1//2" (disc) face plate w 1/4" screw attached to a #2 Morse taper. I had it three days ago and now I don't. I'm looking for a source where I might find another without it costing $30 or more. I can jury rig a hanger bolt woodscrew, and fender washer into a drill chuck but I'd rather find a duplicate. I've checked MSC, Packard, ebay and can't find an inexpensive quickie replacement. Any other turning sources or used part places I might check out?
Re: Looking for screw chuck
Dick Hines
Dick Hines
Have you checked Penn State? Some thing tells me I saw something like that in their catalog
Lyle Jamieson
A better idea
Lyle Jamieson
I don't like to use a screw chuck because I want to be in control of the grain and axis until I get it roughed out. When you drill the hole for the screw chuck you are stuck with that axis. All the ability to change axis is gone. Start between centers and it opens up a whole new world of creativity. See my YouTube clip or Bowl Basics DVD for more details. http://youtu.be/b4xIHTS0yJc
Re: A better idea
Phil Powell
Lyle,
I went to your video, you do make it look easy. Excellent description of the process you use. It was a good learning video. While I was at it I watched several more of your videos.....real good stuff. Thank you for your no BS presentation of the techniques you use while turning. I'll be grabbing a chunk of wood and heading out to the studio. Thanks!
Headed for the you tube tutorial, and
Gary Smyth
the screw chuck is found. Turns out I left it in the local hardware store when I carried it in looking for hanger bolts and some other hardware. The worker there said that they didn't know what the plate (absent the screw portion) attached to a morse taper was for, or what item in the store stock it was to fit, but they figured someone would buy something and discover that the item wasn't complete. They stuck it in the back of the store just in case. Pure chance I asked the right guy in the hardware section as the cashier in the front of the store checked the cashier's lost and found (she found over a dozen pairs of sunglasses and assorted car keys) and came up empty. How about that for luck!
Re: A better idea
I agree with Lyle. I learned it from John Jordan many years ago and it just makes good sense. got a bowl blank with a crack that just wont' turn away. Stop and reposition the centers to move it so you can get rid of it. As you turn sometimes you see some great figure in the wood. If you can move the centers you can take great advantage of this instead of just turning it away. Thought you had it centered so the rings would be right in the bottom but as you turn realize your off just a little. Stop and readjust.
Yes you do end up with a smaller bowl but it's so much prettier.
yes, between centers
GaryG in MD
I quit using a screw chuck for the reason Lyle expresses.
I start all my pieces between a steb center and a live tail center.
That way you can adjust the mounting angles as you find a reason to.
Another good way to go is the "Stirt Bowl Driver" that Al Stirt came up with some time back. You can see the plans at www.alstirt.com/PDF%20files/BowlDriver.pdf
...GG
Dick Hines
Re: yes, between centers
Dick Hines
I also start all my bowls between centers. I am looking for the side grain to dead center of the bowl. I want the side grain dead center of the bowl. It makes no difference to how the bowl is used but it sure looks better. If you start with a face plate of screw chuck you either can't change or is very hard to change the bowl.
