A55 Smoothing Plane
Origin of the term "Banjo" on a lathe?
Peter Toch
Does anyone out there know how the tool rest holder on a woodturning lathe came to be popularly known as the "banjo?" Where, who, or why was the term "banjo" coined for the tool rest holder part of a wood lathe? I did a little research on the web and found many references for "banjo" as that part of a lathe that holds the tool rest, but no references at all as to the origin of name "banjo."
Just a curiosity.
Thanks, Peter Toch
Re: Origin of the term "Banjo" on a lathe?
John Jordan
Yep, Kevin Clay (Oneway) read it described that way in some old industrial arts book. I guess because many of the old ones that bolted down had a flat plate that was sort of banjo shaped.
Shows how things can spread. :) I'll stick with toolrest base.
John
Lyle Jamieson
Lyle Jamieson
Right on John, The hole in the tool rest base was shaped like a banjo so you could pull the base out to the end of the track and the head of the bolt would slip through the enlarged hole. This allowed you to take the banjo off without moving the tailstock when turning spindles.
John Jordan
Do I get a prize?
John
clay foster
You get a DVD of "Deliverance."
Lyle Jamieson
Lyle Jamieson
You are da man...right next to Clay.
Don Evans
Ok, all you seems sooo smart with those answer try this on for size.
Why is it called a tool rest when that is the place the tool goes to do all of its work?
My wall is actually my tool rest cause that is where I rest my turning tools.
Why isn't it called a working tool support? Just one example.
Language is really weird sometimes and funny when you consider what name calling really boils down to.
I guess my point is why not call it a banjo? Is it because you except that for a musical instrument instead of a part of a wood lathe?
i'm going to go to sleep now as I'm tired obviously!
Don
Don then we should probably call the wood a tool catcher since that's what it does. :)
phillip Medghalchi
Peter, I guess just like Ellis was trying to figure out what is the connection between the wood turners and being musician, I think when the first guy went to coin the term he was missing his banjo, and he was little tipsy so he thought he left his Banjo on the lathe and it resembles it like a Banjo. :b
That tells you how English language works in trying to describe somethings. Like who decided the a ship is a "she" and not an "it". and there are so many other words that do not actually distinguish the true meaning of the purpose. Like when you say "Uncle" I wouldn't know which side of your parent's family you are referring to. so, I guess just like the guys above explained it's how it came about.
Uncle is any guy your mom gets caught with
