Band Saw stalling under the load
phillip Medghalchi
Hey, folks,
I have a 14" Jet band saw that I put riser block on it to cut up to 12" Logs, however, when I had to cut big Mesquite or heavier blanks it would stall and on Mon. It did so I took the motor out and cleaned it. What happens is that when you try to start it you hear it hum and i thought it may be the starting capacitor. so, When I gave it a push by hand it started up and got going until I put a 5.5" Mesquite log and tried to cut it into a blank. so, it did it again. Previously, I think I had trouble that motor was not sitting level in it's bracket and it was making little noise and so, i adjusted all that (despite that they think every one is a midget) with small hands) I got it tightened up and leveled too. So, is it possible the starting switch is going bad? If so, is it hard to replace it? Also, how can you tell if it is the capacitor?
Any help would be greatly appreciated?
Re: Band Saw stalling under the load
Dennis in Southern Oregon
If it is not a sealed motor, there is a high likelihood that sawdust has gotten into the starting switch. If you have compressed air, try blowing it through the motor vents. I have had that situation several times with a radial arm saw.
Dennis
phillip Medghalchi
Thank you Dennis, I just came back from Grainger and thye told me that it's not the motor starting capacitor, so I am going to try your suggestion to see if that helps.
If you find that the motor starts intermittently, try blowing it out while the motor is running (take the belt off for safety). The switch contacts will be open while the motor runs and any dust or chips that may be stuck to them will be more easily dislodged.
Dennis
Sounds like you need a larger capacity motor.
Harry Robinette
Re: Sounds like you need a larger capacity motor.
Harry Robinette
If I was doing this I would put a larger motor on the saw. Jet 14's come with a 1 hp motor the one I had just didn't have enough power. I'd be putting a 1 3/4 or 2hp motor on the saw and not worry about any stalling again.
Just my thought's.
phillip Medghalchi
Harry what kind of price we are talking about here? Or do you just find it off of some other tools?
Harry Robinette
Harry Robinette
I got a 1 3/4 hp off ebay for $50.00. It was on the saw for I think 3 years and I sold the saw 2 years ago. As far as I know it's still there.
It took me about a week to find one on ebay but you can check Craigs list also.
You can also ask around you club theres allot of motors out there.
Just to go in a different direction. Is the motor stalling or is a belt or the blade slipping. If you didn't have good tension on either that could happen. the tires on your saw might be worn or full of gunk. Just guessing here but I've had both happen.
phillip Medghalchi
Dennis, I went to it again and took the protective cap off where underneath is that blade fan and below it with compressed air. then inspected the other end which is very much closed up where the pulley is that transfer the rotation to the belt and the BS large wheel, nothing there for the dust to get in. Then, yesterday i took the motor starting capacitor to Grainger and they tested it and works fine.
Here, what I did today. I went the first thing in the morning when I had the energy and the mind was fresh and inspected every thing again first by taking the motor off and try running it W/O load one thing for sure is that I don't think that this BS was designed by Americans, or they didn't have anything to do with it's assembly. Mine is the JET jwbs-14cs
the problem was the placement of the pullies and the levelness of it.
