So the county is cutting down trees that are underneath their power lines. A lot of trees are being cut. So all winter I have been passing two piles of red cedar. No don't stop I said to my self. I lost the battle so I stoped. Nobody was home, I left a note. He called me back, so now I have a truck load of wood, for the price of a bowl or 2.
My question is how do I keep the beautiful red color after it dries.
Dan I haven't figured it out. I played with cedar for a short while and loved the colors after you turn it. Bright yellowish white with a beautiful pink. No matter what finish I applied over it the yellow darkened and the pink went to purple. I even tried just wax and finishes like Krylon fixatif. Nothing worked.
So I had the bright idea of trying to bleach it. I figured If I could bleach it lighter then when it darkened with the finish it might be the color I wanted. I started wiping the bleach on and the bowl cracked into about 10 pieces. apparently the bleach penetrated so fast that those areas were swelling while the other areas weren't and it blew up. Next time I plan to soak the bowl in water first so the bleach will penetrate more evenly but simply haven't had the wood to play with.
The finished piece would have to be kept in a drawer, out of sunlight to retain color very long. Or as Ed McMahon used to say"....... have been hermetically sealed. They've been kept in a #2 mayonnaise jar since noon today on Funk and Wagnell's porch.
I don't even like turning the stuff. It's soft, and sanding can be a real pain as sanding scratches seem to show up days after you thought they were all gone. I think you should have listened to that first voice in your head!
from a really large Eastern Redcedar, Juniperus virginiana. I even used it for the counter top. Because I thought it was too soft for this use, I put it under a tarp / tent, with a space heater blowing in to heat it up. After about an hour, I pulled it out, and as quickly as I could soaked it with CPES epoxy, using the contraction of the cooling air to draw it in deeper. THis deepened the color, as well as making the surface much harder, and so far, it has held the color pretty well.
This was for our cabin, which doesn't have any conditioned air during the week while we are away, so I'm not sure how it will look by the end of Summer. Not that the heat would have anything to do with fading, but I'm sure the lumber wasn't dry, but hoping that my methods will allow it do so without self destructing.
