waterproof glue
waterproof glue
waterproof glue
Skip Beardsley
When I prep bowl blanks I cut down both sides of the pith leaving about a two inch slab. Then I cut the pith out and throw it away and save the two pieces on the outside for tool handles, pen blanks etc.
I want to make a large platter and am going to glue two of these pieces together.
The question is ....... can I glue them together with titebond two (waterproof) glue when the pieces are green or should I wait until they come out of the kiln to glue them?
As always, I turn to the folks on this forum to help with the lessons I still have to learn.
Skip
Re: waterproof glue
Re: waterproof glue
John Veerkamp
I'd wait to glue up after drying. Then you'd be assured that after milling the edges , there would be no added stress to the joint.
My opinion as I've never tried it.
Re: waterproof glue
Re: waterproof glue
James Heaston
What you have there Skip are 2 pieces of perfect quarter sawn blanks. Wonderfully stable. Unless you are wanting to turn them green I would definitely wait after they're kiln dried. Besides they'll be easier to handle & stack.
The only glue I know of that will adhere moist wood together are some of the construction adhesives. (er so they say)
Re: waterproof glue
Re: waterproof glue
John lucas
Gorilla glue will glue wet wood together. I've glued waste blocks to wet bowl blanks. I would not recommend it for your purpose. To much possible wood movement while its drying
Re: waterproof glue
Re: waterproof glue
robo hippy
Well, already covered is to glue when the wood is dry and stable. As to which glue, well, there are 'water resistant' glues, which tite bond 2 is. There are 'water proof' glues which means they are mostly good for out doors use, and the urethane/gorilla glue falls into that category. Then there are marine glues, which are good for wood that is going to be under water for long periods of time. For standard use, the tite bond 2 should be fine. I don't like the urethane glues. They do not fill gaps other than with bubbles, which offer no strength. they are a bit messy as well, and don't take shock loads.
robo hippy
Re: waterproof glue
Dennis in Southern Oregon
Re: waterproof glue
I'm curious as to why you would arbitrarily discard the pith from the center disk. In many woods the pith is attractive in a platter and the disk usually will dry without splitting or cupping badly. You could always cut the pith out later if there is a problem.
Dennis
Re: waterproof glue
Re: waterproof glue
DKWalser
Skip - For use with your platter (after the wood has been seasoned), I'd use Titebond III. Both Titebond II and III are FDA approved for indirect food contact (such as with a glued up blank for a rolling pin or a cutting board). Titebond II is water-resistant. Titebond III is water-proof. Titebond III provides a slightly stronger bond.
For a platter, I think water-proof is better than water-resistant. If your platter is never left to soak in the sink, water-resistant is good enough. I made a cutting board for my wife in the mid-90's. It was left by our kids in the sink once too often and finally came apart after close to 20 years of service. Had it been made with Titebond III (which didn't exist at the time), I think the cutting board would have stuck around longer.
Re: waterproof glue
Re: waterproof glue
Skip Beardsley
Thanks to all for the input. I guess I will wait until they come out of the kiln and then glue them up with tb3 as suggested.
Skip
Re: waterproof glue
Re: waterproof glue
don stephan
My understanding is that Titebond 2 and 3, like similar forumulations, are for gluing together dry pieces of wood that after gluing may be exposed to moist or wet conditions. I don't think TB and similar were developed to glue wet wood.
