Need a good one
Need a good one
Need a good one
Marty
I am in need of a "good", lathe duplicator. I have looked at PSI's,Rockler"s,General Int'l, and Vega. I have a Delta Midi lathe. A gentleman at Church needs about 15 spindles about 13 inches in length. I know I could use a pattern and calipers,but for me it would take a loooong time. Any suggestions? Thanks, Marty
Re: Need a good one
Re: Need a good one
Your would be surprised. Sure it would take a while to make the first 5 but each one will get quicker. Now I'm not against duplicators. I have the Vega and they do a wonderful job if used correctly (that means cutting downhill with the grain). There are also some cuts they won't do such as a square sided tenon. The Cutters are generally V shaped so won't cut straight down. You still have to cut these areas by hand. However they will cut most shapes and do so very precisely and with little user experience.
So you kind of have to weigh the money vs time issue. Also how often will you use it again. If it's a one time thing I would look for a used one on craigslist or ebay. You can even build one. It won't be as good as the real ones but will do a decent job and for a one time project may be the way to go. If I have time I'll do some research in a little bit and see if I can find plans.
Re: Need a good one
Re: Need a good one
Dick Coers
Vega with the carbide accessory cutter is the only one I would consider. I have the mini, but I mount it on the back so I can chase details by hand on the front. Anything short of production back knife lathes will never cut like hand held tools.
