Finish for dishes
Ernie Miller topeka
A friend wants me to turn him some plates from a whit oak tree his dad planted 55 years ago that came down what would be the best finish? any way of preventing it from turning grey?
Finish for dishes
Ernie Miller topeka
Re: Finish for dishes
Ralph Lindberg
For utility use, like dishes, I prefer a penetrating finish vrs a surface finish. That is an oil vrs a poly or lacquer. Wear will cause the surface finish to come off.
Long time range, Richard Raffan points out (in one of his books) that the color in all wood fades, we had best to the best job we can on shape.
Dale Gillaspy
Mike Mahoney doesn't put any finish on his.
I would use Mahoney's walnut oil but bear in mind that Oak has a lot of pores and may not make the best functional plates. If they are going to be decorative to display then of course any finish would work.
don stephan
My standard finish is 3 coats of an oil-varnish blend (equal parts mineral spirits, boiled linseed oil, and gloss alkyd varnish). It sealed up completely a quarter grain red oak breakfast bowl, which has for 4 months so far held without any issue daily milk and corn flakes. A similar ash bowl after 15 months of daily use I took back to the workshop to show customers the durability. I'd suggest you try on a sample bowl or plate first, as it will warm the wood some.
DKWalser
Earnie - If the plates are going to be used, the pores of the wood will need to be filled. For this I would recommend one of three approaches. First, use a commercial grain-filler. Second, use several coats of a sanding sealer (I use 50/50 blend of Deft lacquer and thinner). Sand down to the bare wood in between coats. A close inspection under a magnifying glass after the third or fourth coat will tell you if the pores have been adequately filled. Third, wet sand using walnut oil as the lubricant. After you've progressed through the grits, the swarf should have filled the pores.
Each method has its advantages. A commercial grain-filler, depending on the color, can really accent the wood grain and can be very dramatic. Filling the pores with sanding sealer may affect how the wood accepts your final finish. If you were going to use a stain, for example, the inside of the pores would not accept the stain while the surrounding wood would. This would be true to a less noticeable extent if you were to use a neutral oil finish (as opposed to something with a tint in it). Finally, if your finial finish is going to be walnut oil, you need to be careful to remove swarf from the surface of the wood (leaving the pores filled). Otherwise, you tend to muddy the look of the wood. This isn't difficult, it just requires care.
Hope this helps.
