ADVERTISE HERE - FREE TRIAL
An odd acrylic finish
Lloyd in Mississauga
I have been reading about ways to thin out the acrylic air brush paints as I am just starting out and do not want to purchase the higher quality paints just yet.
In the modeling space, who use air brushes a lot, some are using Future floor wax (now labeled Pledge) as a thinner and to help stop the paint drying in the tip as it is sprayed as well as a gloss top coat. It actually has not wax in it and is just an clear acrylic finish.
Has anyone ever tried this on their turnings as a finish? You can thin it with water or use straight from the bottle and spray it from an air gun as well as add dyes or color to it to use as a tint coat.
Re: An odd acrylic finish
Peter Hyde
Hi Lloyd,
unless they've completely changed the recipe Pledge was always loaded with silicone and was the absolute worse thing you could put on furniture or floors as it works like a dust/dirt magnet. Read the small print on the can carefully before using. Seems as more and more finish manufactures jump on the water base bandwagon rebranding of old formulas is now the way to go. I personally would stick to the pro finish suppliers and manufacturers before using any of the latest fads. I recently used a Flecto water based finish and just slopped it on with a brush and to my amazement brush marks were gone when it was dry, so things do improve sometimes :)
Thanks Pete.
Like I said, I was reading on the modelers forums that they were using this to thin their acrylic paints and gloss clear coat their models in some cases. They were not reporting any issues, and were even covering it with urethane in some cases.
The msds does not list any silicone in it at all (http://www.scjohnson.ca/msds/19189%20Future%20Premium%20Floor%20Finish%20-%20CA%20English.pdf)
It is not a replacement by any means, but may be worth a bit of investigation if you had some under the cupboard already.
