Turning wooden wedding rings?
Keith Newton
My young assistant has a couple of friends planning to marry, that have ask him to make wooden wedding rings for them. He was asking my advice. Well, obviously the easiest thing would to turn a ring with the grain running with the finger, but it would all be short-grain, and very easy to break.
Even if the grain were perpendicular to the finger, half would still be very short-grained.
So, we were discussing doing some really small finger joints, on a 45º, or 60º, then turn it like a segmented bowl.
Then maybe steam bend some strips spiraling around a pipe / mandrel, followed by cutting a long scarf joints diagonally across the face, hoping to be able to pull the sides across to glue together.
And finally to wind veneers around a mandrel, building upon itself, but this would be a pretty tight bend for that.
Do any of you have any experience doing this, and willing to share your technique
Re: Turning wooden wedding rings?
Josh Bowman
I've never made a ring so small, but if you go with the segmented joints, you can just make a solid segmented piece then turn it down and drill it out.
Also wonder it you could steam bend veneer onto a metal ring. Or maybe do the segmented thing above, drill it out and put a piece of tubing inside, kind of like a giant ink pen.
Alan Sweet
Alan Sweet
Here is a video about making metal core wooden wedding rings. BangelGuy has a nice business selling supplies and information on making bangels and wooden rings. Hope this helps.
http://www.youtube.com/watch?v=H9dIub8fMZY
Dick Coers
Stack laminating veneer is also very strong, but the look is different than solid wood.
I got a wood watch as a retirement gift. Lots of disclaimers on the instructions about allergies and reactions to wood. You should suggest he stay away from most exotics.
But with the way some marriages only last a few years.................My favorite marriage quote, Half of all marriages end in divorce, the other half end in death.
Pete in Holland MI
Wedding rings, especially for girls, are very sentimental. A replacement wood ring several months years later won't be the same. Trust me.
A ring needs to be small in cross section & size in order to wear comfortably. It needs to be strong. The grain would have to be perfect, and fine, in order to have any strength and half a chance of surviving. The occasional washing of hands, sweat, soap, various liquids hands are exposed to will wear on any finish, allowing the wood to absorb all these fluids and lose any luster.
My son was considering a metal wedding band with some inset wood. Looks good in the catalog, but we were thinking of the occasional dirt, mud, oil, etc that he gets into, and what that would do to the finish of a ring that is supposed to last a lifetime. He went with gold.
Try making two. Wear one for a month, keep the other on the shelf, and compare them after the month. I think you'll be disappointed on where the ring appearance is heading, even in that short time.
I'd strongly advise against it.
Pete
Dick Hines
dick hines
I have done a couple of rings. Go to Capt Eddie Casterlin's web sight. He has a couple of videos on turning rings.
I turned mine out of some scrap burl I had in the shop. They were not hard to do. Google ring sizes. There will be something like two pages.
Jim Evans
Jim Evans
Keith, have you considered Corian? Many different colors and grains along with not worrying about grain direction. Corian polishes up great and can always be buffed back to a nice finish.
Steve Kniffen
Keith,
I just made one for a friend to give her husband. It was her "willow" anniversary so she wanted some willow in the ring to remain traditional. What I wound up doing was sandwiching a 1/8 piece of willow between 2 x 1/4" pieces of Texas Ebony. I ran the grain on the willow 90 degrees to the grain on the TX Ebony. That way there was no problem with all the end grain running one direction. I'd done this with layered bracelets, too. With 3 layers, you could also run the grains 120 degrees different for each layer to add even a little more strength.
She measured his ring size. I found a sizing chart online. The closest drill bit I had to his size was 3/4" so I drilled out the center, cut off the corners, and mounted it on a 3/4" expanding jam chuck I got from PSI. Turned and sanded the outside to dimension then took it off the chuck and hand sanded the inside. She loved it.
First and only time I've done it. I was glad I made 2 blanks because the first attempt ended in an exploded blank when I tried to make "just one more finishing cut" and got a catch.
Steve
Wood swells !!
Sergio
Tell your friends not to sweat or take a shower with the ring on!
James Heaston
Been reading this thread w/ interest. Wooden wedding bands does creature some problems.
I'm friends w/ some custom game call makers & they talk about stabilizing the wood. They send out pieces or buy 'em from the suppliers. I contacted one & he sent me these links.
http://www.veddermountainhardwoods.com/2009/10/25/stabilized-wood/
http://www.stabilizedwood.com/
http://www.nwfiguredwoods.com/
HTH & no I've never tried any of their services.
Thanks James, that is the way we were headed.
Keith Newton
We had managed to wind veneers around a 5/8" mandrel, glued tightly together with epoxy. I was thinking that the thin denetrating epoxy would be the way to stabilize, but this looks like acrylic was what they are using.
We have 5 rolls about 2" long by 1.25" OD to play with. Two are EI Rosewood, two Beech, and one fiddleback Maple. We can probably get at least 5 blanks out of each to try different things with, so I'm confident we can turn out something pretty tough and stable, as well as nice looking.
I didn't see where they revealed a source for their resin did you?
Re: Thanks James, that is the way we were headed.
James Heaston
Sorry Keith, but not sure how its all done. Jerry, my call making friend, says & I quote "They stabilize the wood by placing it in a vacuum chamber with liquid resin. They lower the pressure in the chamber and the air in the piece of wood is pulled out and replaced by the resin. They leave it in the chamber till all of the air in the wood has been drawn out. Then it is dryer and you have stabilized wood. "
Now you know what I know. That & that my calls take a beating & keep on bleating.
I don't get into smaller turnings. If I don't use an engine hoist to set a block in my Shopsmith in lathe mode then it's to small!
j/k :D
Keith Newton
Yes, I figured the vacuum was part of the process, and I've already used it to get this far, and plan to do more when some of the thin resins that I have ordered come in.
I hadn't checked their price list before my last response, but have since. It seems pretty reasonable, so if I can't get there myself, I'll probably give them a try.
Thanks again. K
