WD-40
WD-40
Lyle Jamieson
WD-40
Lyle Jamieson
I thought I would start a new thread cause the one below gets lost in another topic from John L. WD-40 was mentioned on the forum below (sorry for the poor editing on my part down there)and there was a contributor that showed that it is not a good lubricant. W-D-40 equals Water Displacement #40. They tried 39 other different formulas before they got it right. It is an amazing product for turners. It was not designed to be a lubricant. It is the best thing to use on lathes because it retards rust by displacing the water. It also acts as a slight lubricant but it is not oily, it does not produce an oily dust film, it is not slippery. We don't want the tailstock and tool rest banjo to be sliding around on the bed. Some folks pay a lot of money for fancy lubricants, when most of them are counterproductive on lathes.
Re: WD-40
Re: WD-40
John lucas
Lyle. I worked on all sorts of more or less fine machinery most of my life from cameras and copiers to teller machines and photo processing equipment. I've see. More machines screwed up by spraying with WD-40. It becomes gummy and stops the machines from working. It great for lining a d protecting our bed ways and tool rest but if you need to actually lube something use a good oil
Re: WD-40
Lyle Jamieson
Re: WD-40
Lyle Jamieson
I agree, wd-40 is not a lubricating oil. A lot of folks use it for that purpose.
Re: WD-40
Re: WD-40
TomB
Dri-slide is an excellent lubricant for metal. Molybdenum and graphite. A little goes a long way
Re: WD-40
Re: WD-40
Don Orr
Right on ! I've used it when turning fresh white oak by wiping it on heavy, doing the turning and wiping it off at the end and guess what-no rust!
I have heard that the formula in the spray can is slightly different from the stuff in the gallon can.
Re: WD-40
Re: WD-40
Wally Dickerman in Arizona
Before I retired way back in 1986 I was in the wholesale sporting good business. Part of my business was selling guns and related equipment so I had contact with a lot of gunsmiths. Several told me that WD-40 made money for them. Owners of Autoloading shotguns would lubricate their guns with WD-40. After a bit they quit working. The gunsmith cleaned all the WD-40 gunk off and charged the customer a hefty price for fixing the gun.
Re: WD-40
I was in my friend's shop....
He cleaned the table of is TS with WD-4O. Incessantly. If he cut a single piece of wood and moved to another tool, he would clean the table. He also cleaned every other metal surface the same way. Constantly. Now I admit his tools look better than mine, but not a lot. I had two thoughts, One, He's way OCD, and maybe I should clean mine at least occasionally.
I went home and picked up the familiar red and blue can and wiped everything down. Got some crud off them. Did it again after cutting some wet wood. Later that day I noticed the familiar can was Spot Shot carpet cleaner. OOPS!
Re: WD-40
Re: WD-40
Ron Lynch
When I was but a wee apprentice millwright I thought lubing my micrometers with WD would be a good idea. Not so much, the stuff turned gummy and made it very difficult to operate my precision measuring tools. Live and learn and if you can learn young, so much the better.
