really big gun drill *LINK*
This is cool. I've used smaller gun drills and they still want to wander very slightly but that is without air or chip removal. Would love to try one of these puppy's.
https://www.youtube.com/watch?feature=player_embedded&v=W3H5o2DHloc
Re: really big gun drill *LINK*
Randy Gleckler
I've got a smaller one that is hooked up for use with air, if you ever want to try... I believe it runs pretty true, never had an issue with it.
I have a small one. Not sure what size it is, maybe 5/16. I have never tried it.
Phil Powell
John, have you been told size doesn't matter?
I would like to see a close-up of.......
JamieDonaldson
...the cutting tip grind configuration on a bore drill?
Re: I would like to see a close-up of.......
Jamie It's kind of blunt, about 75 to 80 degrees. Thats the left hand side if you have the hollow part up. The right hand side looks about the same but it's ground back so it won't touch the previous surface.
I have a small one and will do a photo later but I have to head out of town for a few days so I'll do it next week if I remember.
Jim Evans
Jim Evans
If I remember right Trent Bosch uses a Gun Drill on some of his turnings.
robo hippy
Dang it John, every time I am starting to think that there aren't any tools that I just can't live without, some one shows me some thing like this.... You are probably one of the worst offenders... I may have to search, but we had a turner who demonstrated drilling the pipes for a bag pipe. He had a really interesting drill bit that was pretty simple, and would go long distances and not deviate from intended path.
robo hippy
ron bauer
I have one that is 5/16 x 36". It is used to drill a pilot hole for tall pepper mills. The nice thing is that it has two tiny holes along the length that was originally used for drilling lube when doing a rifle barrel. I just hold the rubber tip of my blow gun to the tail end and it effectively blows all the chips. Feed fairly slow while turning at maybe 500RPM. Tons of them on ebay in all diameters and lengths and relatively cheap. The longest I drilled was 20" in cherry and it missed the center on exit by about 1/8 inch.
