I have been looking at a Delta 46-700 lathe at about $450. This is a variable speed lathe but I know very little about it. I would appreciate any thoughts or comments from the group as to the value of the lathe or their experience with it.
I agree that is too much money unless it comes with a lot of tools and chucks etc. I think the lathe sold for about that or less brand new. People have a lot of problems with the pulleys on the reeves drives breaking and I don't even know if you can get parts for it.
The minimum speed is too fast for turning out or round bowls. You would be much better served by a Jet mini lathe with a bed extension. Less vibration, easy parts replacement, and a smoother running lathe than the 46-700. I am a previous owner of one and don't have a lot of good things to say about it.
I agree. I had the 14" version and cannot recommend it. The reeves drive is more than problematic, vibration is pronounced. It is well documented that the tailstock slips no matter how much the tensioning nut is adjusted.
Since this Delta model is not considered a good value -- even by those that have owned them -- let's put our heads together and make some recommendations for Bob to pursue.
One good suggestion already made was a Jet Mini with the bed extension.
I'd also suggest that he could also look for an older, heavier machine that might deliver much better value than lightweight, newer machines. I would much rather get a 50-year-old machine with replaceable bearings than a 10-year-old light-duty lathe. I put a premium on lots of cast iron, unless you need to travel with the thing.
An older Delta, a Powermatic 45 or Powermatic 90, or a General might be found -- especially a floor model from a defunct high school or vocational school shop program -- could be the best overall value. I would rather see these shop programs continued, but sadly there are a lot of used lathes out there from discontinued woodworking programs. The older Rockwell/Delta and Powermatic machines can be updated with new bearings, and serve you well for decades to come. Even upgrading one of these old beauties with a variable speed motor is not that difficult.
Keep Lookin' Bob! You're sure to find a better value out there than the 46-700.
Safe spinning,
Brad Vietje
Newbury, VT (STILL have 2' of snow on the ground! When does Spring start?)
There is a General 160 for sale in Woodstock, Ontario (less than a hour and a half from Buffalo) for less than $1000. Check the Swap Meet at Canadianwoodworking.com forums.
Well I like my delta very much. I'm worried about the company behind it but so far its the best mini I've had. I would have to recommend the new jet midi if I was out looking today
