Drilling out pith in hollowforms/urns/etc.
Richard Jones
Who does it, how big of a hole at the base while drying, have you had good luck?
Thanks,
Rich
Richard Jones
Thanks,
Rich
Re: Drilling out pith in hollowforms/urns/etc.
John lucas
I've done it with a hole about an inch or so. Kind of depends on how big I make the base a d how big the pith is. I like the even shrinkage you get when hollowing a vessel that way
Frank J
I have drilled out pits .. I taper the hole an plug after it has dried a bit the plug can be trimmed off you can't even see the plug
phillip Medghalchi
Sorry not following you.
yes
GaryG in MD
If you're roughing out a green endgrain blank with a center pith, and haven't got the time to turn it further while green, that's an excellent way to improve your probability of drying it without cracking. The more of the interior you remove, the better your chances will be. Anchorseal the outside, but not the inside. That lets the inside dry more quickly than the outside and creates a compressive stress that will help hold it together. Keep it in 3 nested brown paper bags in a cool, dry (but not super dry) area. Early on, reverse the bags every few days to keep mold from forming. Soak the remaining (thinned) pith area with thin CA glue. Watch the pith area carefully, every day or two early on, and CA any microcracks that develop. I've also used this method for making things you want to twice turn like goblet blanks, box blanks, tea candle holders, and kenzan holders. Works for me. ...GG
Re: yes
John Jordan
I turn start to finish, and put the hole in after taking it off the lathe-done lots of them this way. 3/4-1" is about right. IF YOU LEAVE thick walls in the bottom, you will still likely have problems, make them even. If the bottom is already crack, and some woods are ALWAYS inherently cracked, drilling a hole won't help, and glue isn't much help, either.
There's a couple of articles with pictures and drawing and details on my website.
John
Here's a link *LINK*
http://www.johnjordanwoodturning.com/John_Jordan_Woodturning/Home.html
Thanks, guys
YES -- What He Said.
Brad Vietje
I pretty much learned from John Jordan and David Ellsworth, so -- no surprise here -- I do what John does!
In general, you are about 4X as likely to have problems with checks +/or splits when turning centered on the pith -- at least until you get enough experience with various woods. How you store and handle the wood will depend on your local climate, the season, indoors vs outdoors, heated vs unheated, etc... Eventually, your losses will be very few.
You will find that while most hardwoods follow general rules of thumb, when you get into a Black Cherry that grew in a windy location (lots of potential ring checks, and twisty grain), or very crack-prone species with high shrinkage (Am. Beech, Apple, Lilac, etc...), you can still lose a few.
So now -- what to do with the drilled out hole where the pith used to be? I'd like to learn how others deal with this.
Safe spinning,
Brad Vietje
Newbury, VT
Brad, the rest of JJ's lesson.........
JamieDonaldson
.....from years ago was to fill the hole with a matching wood plug when the turning is dry. Works for me!
