'Nuther McNaughton Question
Brad Vietje
I have an older McNaughton Center Saver from about 12 years ago -- not at all the same as Chuck Engstrom's. My dad bought this setup and only got the largest set of knives, and I inherited it when he died in 2004. These are from before they were pointed at the tip, but were a straight cutting edge, skewed at an angle from the tip.
I would like to get the medium and small knife sets, and wonder if anyone has experience with this? My set was manufactured before the smaller knives were released, so there are only 2 guide positions. I heard a rumor that to use the smaller knives I would have to adapt the medium size guide posts to accommodate the narrower profile of the small knife set. One idea was to put a short piece of copper pipe or tubing over one or both of the guides to narrow the gap so the smaller knives wouldn't rattle about. I'd also have to either raise the unit to use the smaller knives, or consider some sort of spacer to lift them up to the same center height as the other sets.
I'd like to be able to invest in the medium and small knives without having to buy a complete new setup, which I can't afford to do right now. If there's no good solution to adding the small cutters, I'd probably just add the medium set, which should require no adaptation at all. I'd appreciate learning from the wisdom of the group on this.
Safe spinning,
Brad Vietje
Newbury, VT
