Ha!
Ha!
Keith Tompkins
Ha!
Keith Tompkins
And you thought I couldn't do a serious turning! :D The "cheese" and martini glass are one piece; I've figured out a new way of turning on several different axes..this piece uses four. The mouse is sitting in an epoxy cocktail. Any comments welcome...
Re: Ha!
Re: Ha!
bowlman
WTF!!!!!!!!!!!!!! I laughed so hard the tears ran down my .... leg. At least I think they were tears.... I know it was my leg ...
Geat work ... hope to see you in Phoenix ...
Re: Ha!
Re: Ha!
phillip Medghalchi
keith, very original and different. Well done. I wonder about you and the mouse. Lately you have been amused by them.
Re: Ha!
Great fun!
Re: Ha!
Clint Searl
A keeper. Great work.
Re: Ha!
One happy mouse!
Re: Ha!
Brad Vietje
Re: Ha!
Brad Vietje
Fun piece, Keith! Looks like a happy little fella, probably prefers drinking to eating cheese because it won't stop snowing!
I'm trying to see the 4 axes, though.... Looks like the martini glass is on one, the cheese another, and if that's a bottle cone or similar on the bottom, that would be a 3rd...
Can you 'splain it, or post a photo from a different angle?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Ha!
Don Leydens
Re: Ha!
Don Leydens
As I said before, you should both be happy (the mouse and you). This is cool!
Re: Ha!
Dennis in Southern Oregon
Re: Ha!
I'm guessing two of them are used to slice the cheese into a wedge.
Dennis
Re: Ha!
Joe Bradshaw
Re: Ha!
Joe Bradshaw
I guess that you could call it a soused mouse.
Joe
Re: Ha!
Dick Hines
Re: Ha!
Dick Hines
Great stopper. Your mind never stops working does it Keith?
Re: Ha!
Keith Tompkins
Re: Ha!
Keith Tompkins
Thanks for checking out my mouse! I appreciate the kind words! I will try to illustrate how I turned it:
first turn a cylinder. I Fabricate a plywood faceplate with a slot milled in. Cut two pieces of wood to fit into the slot so they can slide in the slot. Mount the cylinder between the two pieces on centers. In other words, the cylinder is mounted on centers on the faceplate, then the whole thing is mounted on the lathe. Turn a flat on one end of the cylinder. Then, rotate the cylinder to cut another flat spot. That creates the curved part of the cheese block and the two triangular flats. Now, approximate the center of the cheese block, which will be different than the original cylinder's center. Put between centers using the new points, and turn a tenon. Turn the goblet in the usual way....unless an offset goblet is desired, of course! Use flex-shaft to create holes in cheese, sand, airbrush. I think this is only the beginning of this technique...I can envision many turnings that would never appear to be turned on a lathe.
Re: Ha!
Keith Tompkins
Re: Ha!
Keith Tompkins
Dick, It ain't easy being me! :D
Re: Ha!
Re: Ha!
Dick Hnes
I noticed that when you were at the NC symposium last Nov.
Re: Ha!
Re: One happy mouse!
Bernie Rose
That mouse looks like she might be a Packer's fan,-- hic!.
Re: Ha!
Leo Cuellar
Definitely not "Vin Ordinaire"
Re: Ha!
Re: Ha!
Mike Foster
That is a great description of your process Keith. About what I had envisioned. I agree that there is a lot of design opportunity with the technique. So now I bet you get remarks on the lines of what I got on a couple of my pieces. Why not just take it to the bandsaw? Why on the lathe? My answer is because I'm a turner and because I wanted to prove I could.
Re: Ha!
Keith Tompkins
Re: Ha!
Keith Tompkins
Thanks Mike. You are correct! I turn a cube during some of my demos. Most people think it's impossible to do, but when they see it done....it's easy. They always ask "why", when it could be easily done on a table saw or bandsaw. My answer is: "It would take three hours to clean off my table saw". But seriously, if I can turn a cube on the lathe....what else can I do?
Re: Ha!
Re: Ha!
phillip Medghalchi
Keith, we all know about your ability, now here is your next challenge.
Can you make a mouse that like this he drank but then make him dangle on the side of the goblet like trying to hang on so he won't slide off.
I think this will prevent you from catching the poor thingy and dunking him in the drink. :D
Now we know you can do it. You already proved your creative thinking.
Re: Ha!
Keith Tompkins
Re: Ha!
Keith Tompkins
Phillip, I'm way ahead of you! :D Also a multi-axis mouse.
Re: Ha!
Re: Ha!
Bart Leetch
Before you know it Kieth & his lathe will be dancing with the stars.
The Disney of the turning world took how many axis at how many RPM's to turn that mouse?
Re: Ha!
Keith Tompkins
Re: Ha!
Keith Tompkins
Hi Bart, I can't think of a nicer compliment! Thank you.
Re: Ha!
Jim Barbour
Re: Ha!
Jim Barbour
Come on Keith -- How are we to convince folk that turning is a serious art if you keep cranking out such magnificently humorous work with such endless (and seemingly effortless) imagination? Absolutely glorious - reminds me of the end of many a day fishing years back - I had a bass plug that looked a lot like that mouse, and even more so after the fishing was past and the après la pêche festivities were well underway.
Re: Ha!
Keith Tompkins
Re: Ha!
keith tompkins
Hi Jim, Thanks, my friend! I'm speechless :)
