Veritas - Innovation in Tools
Old Kelton coring guide question
Chuck Engstrom
Hi folks -- I have an old Kelton center-saver set and am ignorant about the use or purpose of a set of holes (photo) in the blade guide for what I would assume to be an align pin to prevent the guide from sliding left and right. Could someone please educate me on what I'm supposed to fo with this, if anything? Does anyone have the original manual available?
I realize that Kelton is up to Mark VIII on the blade guide post rig, and my set may be back at Mk. I. In a workshop last week with Warren Carpenter, with extensive discussion and demo of coring, several of us with this old version of the guide post struggled for success and are hoping to learn something about this set of holes that might improve our luck. Any tips will be much appreciated.
Thanks -- Chuck
Re: Old Kelton coring guide question
robo hippy
This is one that I haven't seen. Got my first one some 15 years ago.... Maybe another picture of the entire rest.
robo hippy
Chuck Engstrom
Hi robo -- thanks for your interest. Here's a shot of the whole thing in the banjo. The two-sided yoke at the rear rotates through 90° around the center post and 2-1/2" behind it, where it starts as the ring just under the cross-slide. The slotted blade holder rotates freely in a socket in the top of the sliding cross-piece, which has 1-1/2" movement side to side unless you put a pin in the hole in the other photo and shown here slightly off-center.
I hope this pretty much shows what the first photo lacks. Thanks again -- Chuck
Chuck Engstrom
Thanks, Dwight. I have sent them the first post here copied into an email.
robo hippy
Well, I have never seen that particular set up. Must be older than my turning time. The only thing I can think of it that maybe for a through pin if you want to off set the tool rest.
robo hippy
Carole Valentine
Maybe wrong, never seen one like this, but is the hole threaded? Perhaps for a set screw to fix the sliding portion at the desired position? Probably an M-8 or M-6?
Answer from Kel McNaughton
Chuck Engstrom
No, Carole, it's not threaded. Very prompt reply from Kel McNaughton says:
"The holes accept a cross pin which enables the turret to be set in a fixed lateral position."
I've asked him for further info on when one wants to be in a fixed lateral position and when sliding freely.
Thanks to all, further thoughts certainly welcome.
--Chuck
Further Answer from Kel McNaughton
Chuck Engstrom
Further response from Kel McNaughton, who has very kindly answered twice today from half-way round the world:
"There are some instances where you might not want the blade to follow an existing kerf , e.g., widening the kerf, a locking cross pin helps on such an occasion. Some turners, preferring that there was never any lateral movement, have left the pin in permanently. The option is there for you to use. I suggest that you try both options and see what works for you."
I will keep working at this and hope to get better results soon.
Best to all-- Chuck
