Gotta make me a demo gouge like this *LINK*
https://www.youtube.com/watch?v=SldVi1kW-9k
Re: Gotta make me a demo gouge like this *LINK*
Rob Wallace
I have a wooden-model demonstration gouge that is 5" in diameter and about 18" long, with a "V" flute and is double ended - one end with a traditional cross grind and the other end with a swept-back grind. It is very useful when teaching, particularly when there's no close-up video available. I don't have a wooden demo model for a spindle roughing gouge, and probably should make one too.
By the way, this guy's German is very understandable, without dialect, and with clear pronunciation. I am not totally fluent in German, but in this case, I caught every word, and it is quite clear he is a good demonstrator and good teacher. I have just subscribed to the Holzwerken You-tube channel. Thanks for posting this John.
Rob
Demo gouge ...
George Taylor
Lyle has videos on YouTube with a bowl gouge model showing push vs. pull cut. It was very useful to me since I tend to be more of a visual learner. Here is one of them:
http://www.youtube.com/watch?v=1HF9IGdHCTA
George
#4Flute indicator
Bill Howatt
A demonstrator in our club made a gizmo that clamps onto his gouge near the handle holding a piece of dowel that sticks up about a foot. The dowel is centered over, and is perpendicular to the flute. Makes it easy to see how much the gouge is rolled for various cuts.
Bill
Re: Flute indicator
Rob Wallace
I have the same kind of flute indicator, but mine is made from a 1/8" dowel and a rare earth magnet glued to the end. Enables people to see the "roll" of the tool easily.
Rob
Re: Demo gouge ...
Lyle Jamieson
My wood model is pretty small but helps a lot to see what is going on.
#7That demonstrator is using the ..........
JamieDonaldson
...largest continental spindle gouge I've seen in a looooooooog time, and I'm not talking about the mock-up wooden model. Rude used to have a gouge like that, and it requires a bit more skill than just a spindle roughing gouge.
#8Re: Gotta make me a demo gouge like this
robo hippy
I have 2 props that I use. One is a half ring, about 1 inch wide, 1 inch thick, and maybe 4 inch diameter. It has a center line. I stand it on the ways of the lathe, and let it rock a bit till it stops, "now, this tool is balanced". I have half of a disc as well, about the same size, and it has a gravity needle in the middle, and use it pretty much the same way. As I roll it, the needle points down, showing which part of the gouge should be on the tool rest so the tool stays balanced. Unbalanced tool will roll into the cut. Huge catch, things blow up, etc....
robo hippy
#9Re: Gotta make me a demo gouge like this
Don Orr
That is one neat demo tool. Also some excellent demo tips that I will steal-I mean adopt-into my demos.
I have 3 large bowl gouge examples made from baseball bat blank rejects-each with a diffferent "grind". I made them on the table saw the way you would cut cove molding.
#10You need a set of these...
Dale Bright
Instead of making one, you could get a set of Tom Boley Signature Series tools. All I have time for now is a quick cell phone pic. I am busy packing for a week at John C. Campbell. I will post some better pics when I get back home. These are a birthday present from Tom and this picture does not do them justice, they are beautiful demo tools.
