I have a lot of horizontal cast iron surfaces near my lathe now and need to protect them from causting shavings. My shop is too hot in the summer to put up anything like shower curtains so I'm looking at netting. Anybody have any ideas. Bird netting and deer netting looks like the holes are too large and shavings would hang up in them.
I'm going to the fabric stores today to look at the various netting kind of fabrics they have. I'll do more searching on the internet but most or what I'm finding is industrial and little too expensive for this purpose.
Mesquito netting looks good if I can find it in white or something other than OD green. Maybe a good Army surplus store. We don't have one in Cookeville that carries that kind of thing.
Some sort of vertical strips like they use at warehouse doors and on freezer cases? You could use the tracks for hanging blinds at a patio door. If you made them right, you could walk through them.
I can't imagine that crud would not hang up in any kind of netting.
How far of space do you have between the lathe and what you want to protect? Does what you need protected need to go the floor or would three feet or so off the floor work?
I had the same issues and found that shower curtains do work great but I got the cloth type rather than the plastic type (they breath) for the back of the lathe and behind me. I use a top sheet for a king size bed at the end of the lathe which goes to the floor for protection. None of these are close to the lathe itself which does not hinder me from keeping cool because I mounted a big powerful fan from the ceiling pointing directly at me when turning - also helps keep dust from getting to me during the summer. I also use shower curtain hooks (metal type) so I can slide them open when not needed. They slide on some old conduit I had laying around. All of the curtains and bed sheet were purchased at goodwill and were in great condition and cheap. My only concern of any type of netting is chips will grab even the smallest mesh and cling.
Barry I bought a bunch of clear shower curtains for that purpose but they block too much air circulation. I'm using them now to cover up the attic portion of shop to keep dust out of there.
I only need to protect 3 sides. The back side of the lathe faces the garage door which it won't hurt and I can open it up during the summer. Mostly just trying to contain the shaving within about 5 feet of the lathe on 3 sides. If they hang down to about 2' from the floor that will be enough. Just don't want all those shavings on the table saw, jointer, (motorcycle), etc. I have to turn 3 green oak bowls here shortly and that's what finally promted the search. Oak is really nasty if it lands on the table saw.
schools are getting rid of there old projector screens- i picked up 6 screens for free- hang from ceiling around lathe- pull down only the ones needed, mostly for rough turning bowls, works great and doesn't stop air flow-as the top and bottom are still open- only pull down to about 3 feet from floor- when done roughing put them back up- nothing in the way like a shower curtain-
John, I could certainly turn out to be wrong, but my opinion and many years of experiences tells me you are trying to reach in a direction that just will not make you happen. I think that because 1. and material (netting etc) that will stop blood sucking insects will also block a lot of air, even regular window screen blocks a lot. Then there is the keeping it clean problem so what little air that can get through will make it.
Here is the direction I would look harder at. Time wise I think it would be probably a wash to just treat your table tops regularly and cover them instead. A cover for just the top that hangs over the edges 4 to 6" should do it. That makes cleanning the tool (table saw etc) quick to use, just pull the cover all taking care to dump the materail laying on it to the floor for clean up there. You have to deal with that material anyway somewhere whether on the netting or where ever it is deverted.
I use BOSTIK products on may cast iron tops and that is also protection. I've never had rust problem unless it got on there during shipment. I want go through cleaning and treating that as I know you know the drill.
I have two advantages that also help me, one is cyclone Onieda unit piped to all machines. Second is air conditioned and heated shop with heat pump unit. Proper dust collection keeps me from random moving dust problem in hold shop, I don't even need an air scrubber.
Really important (to me anyway) is I was trained that NO job is complete until the clean up is done. Everyone that see's my shop is amazed at how clean it is. It's just that I know keeping up with it is easier in the short and long run.
I would really look at table top maintenance with the Bostik wax spray (or equal brand) and just cover them up, then clean up floor.
When doing thinks like the oak with all that TANNIN in it you may want to do 2 or 3 wax and rubbing it out to a shine before turning them then the cover can be pick up at 4 corners and dump straight to the trash container, easy that way. If dealing with drier wood, I would just dump it to the floor and vacuum. I NEVER SWEEP THE SHOP ALWAYS VACUUM. Sweeping fills the shop full of air borne dust.
If you are ever in the Raleigh area pls come by and take a look, my set up has been a work in progress for 45 years. Wish I had pictures for comparison showing what I started with. I'm in the AAW directory but under Clayton, not Raleigh.
Don
North Carolina Woodturners Guild (http://www.woodturnersguild.com/ )
Don I've done a lot of camping over the years and mesquito netting passes a lot of air. On on my objections to not hanging curtains is simply the clean up is such a pain. I don't have a wide open shop. There's stuff everywhere and the shavings get under,over, and around everything. I even cleaned shavings off of a shelf that was 7 feet in the air and 10 feet from the lathe the last time I was cleaning the shop really thoroughly. Seems to me like it would be a whole lot easier to clean up an 8x8 foot area with only the lathe and grinder to sweep around.
I can always open certain curtains depending on what I'm turning and where the shavings are going. Most of the time after initial roughing I could do with a small curtain to my left and behind me. The back side of the lathe is the garage door which will be open in the summer.
Been thinking about those behind the lathe when I do photography for articles. Could pull it out of the way when not needed and it will stay clean and white.
If you had a sewing machine, why not think about combining the ideas given...
Take the fabric shower curtain and cut it into 2 foot strips 3 feet long, and do the same with the nylon window screen. You then sew the layers edge to edge to build a panel 3 feet wide and as long as you like. With 3-4 of those over lapping on the edges so you can walk between them, you could block you chips, see though and have the air flow.
If you design it right, the solid curtain could be in areas where the chips tend to hit the most and the screen in the areas you want to see through to watch the world go by while turning.
Jeff I'd have to roll up the screen all the time which I think would be a pain. The netting I could push aside like curtains. I am going to cut it in strips so I can easily walk through it.
Cut the shower curtains into strips and then use an old soldering iron to burn small ventilation holes between 3 1/2 and 6 feet from the floor. My concern would be that any kind of fabric would catch and hold shavings and small particles and clog in time. Staying with a plastic material should be just a matter of blowing it off periodically.
When not needed it is held back against the wall with Velcro.
Track is conduit and shower curtain hooks.
Mesh is 3/8” X ½” but probably nothing larger than ¼” X 3/8” could make it through. Probably even smaller than that unless it hit “just” right. That don’t state but I would guess about six pound test.
Does catch some curies but a light shake clears them.
I had to add some bolts at the bottom for weight.
It comes 13 feet wide and I could have gone to the floor but instead just cut it in half so it is 6.5’ long.
If you have tall ceilings (12’) you can still go ceiling to floor. ($9.00 for a 13'X20' piece)
Netting is 45 cents per linear foot, 13 foot wide. Item OR38-C
Now that's what I wanted to hear. Thought netting with that large of a hole would be a problem. At that price it's worth a try. If it doesn't work I'll just use it to control my neighbors kids.
Well, I can't imagine netting not ending up looking like my socks after a day of being knee deep in shavings. Maybe the plastic sheeting and a box fan in a corner, or a cut out square. When it is hot, I will generally have a fan on low speed blowing on me. Evaporating the sweat does cool me off.
Hard to cover everything in a small shop. I have to hang so many things on the wall so a curtain to protect them is so much easier and faster. I did it after having a lot things that were hung on the wall start rusting after a session of oak.
To reduce water spray going everywhere when turning wet blanks, I have mounted a few standard spring-loaded window shades behind the lathe and behind me when I am turning, containing the spray in the line of fire. (I have also clipped a white terrycloth towel above the lathe to capture upward spray too!) These used window shades are frequently sold for a dollar or two each at garage sales, and are extremely easy to mount on a board screwed to the floor joists above my operating position. They are effective in keeping the spray water and chips contained in the lathe area, and quickly "disappear" by retracting up to their rolled position near the ceiling (i.e. no curtains or nets to gather and pull to the wall or elsewhere). They are generally white (at least when clean!) and enhance the lighting around the lathe when they are pulled down and are in place while turning (this is similar to the projection screen recommendation; however most places I have seen screens being disposed of are selling them for a lot more than window shades at a garage sale!).
Having done mist netting in the field for both birds and bats for several years, my only vision for seeing a net set up around the lathe would to come back a few hours later to see John tangled in the net. We would then have to get him untangled, take all the necessary critical measurements of him, and then put a band on him with capture number before releasing him back to the shop!
I will be interested to see how the net works, and if the suspected situation of chips getting caught in it actually results in this anticipated problem. Please post results after you get a chance to see how it works out.
I used to take groups into the wood to teach nature photography. One place we went had these ladders that go up and down some cliffs. To keep anyone from falling they put cages around them. One of the ladies asked me what these were. I told her we all get inside and then bears come and seal off the ends and relocate us to another part of the park.
Ray is right. A friend of mine made a cage with chicken wire and the chips snagged in there big time. At least with chicken wire, he could brush it vigorously. With a string-type net, no such luck. Joe
