I have a homemade bowl steady that works pretty good. Often though I just use a Oneway spindle steady that lives semi-permanently mounted and shoved back and under the headstock. Since I actually have two spindle steadies, I occasionally used that trick of stacking both together with a longer mounting bolt. This is not without issue as they have to be sissored which takes up more room on the beds and may interfere with the banjo. And without adjustment, the wheels may not be rolling on the vessel perpendicularly. So I had a thought, why not mount both steadies on one base. A bit of layout, drilling and tapping (metric) and I was in business. There was already one mounting hole set on the front end, I did six more holes and can see I could use more. (The adjustment range of a Oneway Spindle Steady isn't all that great.) I found this system more conveinient than bringing in the bowl steady and nearly as solid.
What you are using are Oneway BOWL steadies. The Oneway Spindle Steady has three wheels and multiple points of adjustment. I have both kinds.
Before I got my Advanced Lathe Tools Center Steady, I was using a similar arrangement with one bowl steady and one spindle steady in the same configuration you have shown, for 10 years or more. The set-up worked OK but was always a compromise, although better than the bowl steady alone, particularly for taller vessels.
The Oneway Spindle steady does a good job capturing stock between its three wheels and taking out the center whip when long spindles are being turned. I routinely use it when I am doing a baluster replacement job, for example.
