I'll be in Concord NC doing a threading demo. So I'm going to ask for your help. As you know it's hard to get woods for hand chasing threads. I use Cocobolo, Blackwood, Boxwood, and Osage Orange. What other woods have you used with success. I'm told katalox (sp) is good. I bought some but it was still wet so haven't used it yet. Mark StLeger uses hard maple. I haven't tried it but did have some unknown maple. Whatever I have doesn't work.
I do chase threads in epoxy and teach people to thread using PVC pipe.
Bradford pear and hard maple will thread fairly well.
A trick that has given me better threads on secondary woods is to stop about half way through and give the threads a light wipe with CA, and another light wipe very near the final passes.
I also use Bradford pear with good success. I use shellac instead of CA, and it works pretty well for me. Also, a diamond hone is your friend for chasers, especially with pear. A couple of swipes makes a huge difference. Also, not much luck with pear with anything finer than 20tpi, and 16tpi being the best, at least for me. Even coarser may be better, I've just not tried it.
John, I did a threading demo for my club last month. My approach was to teach how to thread rather than to just thread a box or something. Like you, I used PVC to demo the process of cutting both the male and female threads. My point is this is a good way to learn to cut threads or regain you skills if you haven't cut any for some time. I also covered suitable and unsuitable woods and ways to stiffen the less than suitable woods such as thin CA, and minwax wood hardener.
Of course, the lottery winners could just learn hand chasing with ebony, boxwood and blackwood if they wish.
Additionally, another member demonstrated threading with the Baxter threader which, as you know, will thread very well on any wood. The demo was well received and several members have ordered the hand chasing tools.
I hope this may give you some help planning your demo.
Cyril I will be demoing the Baxter threader as well. I use it mostly simply because I can use almost any wood. Especially if you take a light pass followed by some thin CA. I put threads in Box Elder doing this and that's about as soft a wood as there is.
According to Allen Batty, the only American wood that threads as well as box wood is Mountain Mahogany. It might be a bit late to send you some.
I have posted about this as well, 'Timing' your threads. For the threading jigs, I use the Klein, you can time the threads so you always have about 1/4 turn to get them to line up. I put pencil marks on both pieces where the grain lines up. I screw the piece onto the x/r jig, with the line at 12 o'clock, and screwed out as far as I need. Then I use a thin spacer, 1/4 inch plywood works fine. Slide the jig up till it just touches the cutter. Lock it down and thread. Key is to have the lip on the male part EXACTLY 1/4 inch deep. The lid is mounted the same way. I found with the 16 tpi thread, with the male part mark at 12 o'clock, the female part needs the mark to be rotated to about 11 o'clock. Yours could be different. It always bothered me that some times you would need to adjust the shoulder almost the full 1/16 inch, and some times only 1/64 inch. This gets the same results every time.
Hope that makes sense. I do mount mine on wood waste blocks.
I'll have to try what your suggesting. Not sure I totally understand it by reading it but I'll put a piece on the lathe and see if I can understand it visually.
I don't know where to get mountain mahagony. In fact a lot of the woods are kind of hard to get, especially boxwood.
I do have some Mountain Mahogany. It was growing at 8500 feet out side of Las Vegas. Not a mahogany, but dark red in color. It would be a bit late to get you some in time for your demo, but a trade could be arranged. I always rough turn pieces for threading and let them sit, no matter how long they have been 'dry'.
The problem with getting the grain to line up is being able to start in the same place every time. With the pencil marks up, that gives a repeatable register mark. By using the 1/4 inch spacer, or even less if you have some model airplane 1/16 inch thick plywood, you can start in exactly the same spot every time. This does come in handy if you over cut and have to remount to cut the threads down a bit farther. With the bottom of the box/male piece, you need to be screwed out about 1/2 inch away from the jig. With the lid/female piece, you need about an inch so you can unscrew it, take it off, and test fit it. Having the bottom lip at exactly 1/4 inch of threads, this gives you another exact/repeatable reference point for starting. I do need to get a video clip of this done. Much easier to explain that way. I started with having the pencil register mark at 12 o'clock on both pieces before starting to cut the threads. First one had the register point just a hair past meeting up. Next time, I put the lid register point at 11 o'clock, and got about 1/4 about a 1/4 inch space between the marks on the good side, and only had to adjust the shoulder down a tiny hair for the grain to line up. It is easy to repeat.
I have had very good results with bocote, katalox as well as Zapote. These are all reasonably inexpensive compared to what someone referred to as "uranium enriched woods" i.e. pricey like mopani, boxwood and African blackwood. Burmese blackwood does very well at about 1/3 the cost of African blackwood. These all do better than Bradford pear, dogwood and Mountain laurel which are ok. I have heard red tip is excellent but have not had a chance to try it yet.
Mike I called Pete Kekel from big Monk Lumber today because I had talked to him before about thread chasing woods. He said Mark St Leger likes Katalox. It turns well and none of his students have ever had an alergy problem with it. That is something you have to consider when doing a demo. I like to chase threads in Cocobolo but won't do it in front of an audience.
Desert Ironwood and Olive are as good as boxwood to chase threads in.
If you are careful, you can even chase them in box elder and big-leaf maple.
Most any wood will work if you are careful enough. Sometimes it is nice to have some paste wax to make your tools a little slicker.
One of the most difficult woods to chase a thread in is any of the palms. That combination of hard and soft make it difficult to prevent the crowns of the thread from crumbling.
