A55 Smoothing Plane
Let there be light
Let there be light
Let there be light
Dave Long
I'm leading a panel on subject of lighting at the AAW symposium in Phoenix — the best way to light your shop, the best way to light your booth at a craft show, the best way to light wood art in home (either work you have made or work of others which has been collected). Give me some tips or suggestions on how you light your shop, booth or home.
Re: Let there be light
robo hippy
Blue max lights, or Ott lights for the fixtures. Any hand quilter or needle point sewer uses the Ott lamps. I use Blue Max, which used to advertise on the back of Woodturning Design. I think Betty Scarpino uses a different type of lamp. Basically, the closer to natural spectrum the better. These type of lights show you the stuff you miss till you take your piece out into direct sun light. I will be in the vendor area in Phoenix.
robo hippy
aka Reed Gray
Dale Miner
Woodturning is only one pf the activties that gets done in my shop.
With 12 foot to the bottom chord, hid lamps work the best for me. High pressure sodium have to much of a yellow cast for close work and I have found metal halide to be a good all around light. The slow startup and slow restrike is a down side to hid lamps, and a few flourescents are used to get some light quickly after entering.
I use a flex arm lamp on the lathe with a cfl.
Add Internal Lighting to the list?
Re: Add Internal Lighting to the list?
Dave Long
Charlie, how would define internal lighting??
Stuart Johnson
My doctor came up with some nice color photos when I had my colonoscopy. Can't get much more internal.
Dave Long
Thanks for that visual, Stuart. I won't make you the butt of any jokes.
Steven Antonucci
"Crack" me up!
I got the same photos. The good news is I can now tell the difference between by %$#$ and hole in the ground. I heard there was some speculation about that at my office.
Brad Vietje
In Praise of Bad Lighting
Brad Vietje
I have seen many shops with very "good" lighting... well placed, adequately bright, diffused, color corrected, and absolutely useless to see surface flaws in our turnings. While "good" lighting can be essential to our safety, vision and comfort, it's pretty handy to switch off everything except a single, unfrosted halogen or incandescent bulb to inspect our work. This "bad" lighting will show many more details such as sanding marks, slight ripples, torn grain, and deadly cracks.
I strongly recommend all turners interrupt their "good " lighting, and use "bad" lighting to really see what they have turned -- at least for a few moments -- before finishing a piece and removing it from the lathe. I also recommend it when the bark has been removed, and before investing much time in turning something -- this is a good way to eliminate cracked wood that should be burned, not turned.
Getting some experience at seeing tiny details at the border between light and shadow can be very useful. Sensing curves from very subtle shadow details is something I learned in fabricating and testing optics, and it can be extremely helpful in turning, too.
My 3 cents,
Brad Vietje
Newbury, VT
ideally you need a point source of light
And it should be on an easily moved arm. This allows you to both move the light and rotate the wood looking for scratches. I used to use a clear light bulb with just the filament but they are hard to find now. My tactical flashlight works pretty well. It's very bright and puts out a fairly narrow beam.
At present it is hard to beat .........
JamieDonaldson
...the economy and utility of halogen lights, but LEDs will eventually evolve to be a very functional and economical replacement. The compact size and low voltage track lighting fixtures work well in applications such as a show booth or similar display, yielding broad spectrum color balance and illumination placement control. I'm seeing more show requirements for low voltage lighting, reducing the wattage loads down to a specific maximum allowance per booth.
Dale Miner
TMI
Too much illumination?
