Question on turning a small rose vase.
Alan Sweet
I want to turn a rose vase in which a a glass insert placed. This allows a flower to be watered in the vase. The insert will hold any water, be removable and will be 3/4" in diameter. The insert will be 5" long. The vase will not be more 2" in diameter. With a flare top, so that the insert in recessed about 3/8". A 13/16" hole is fine for holding the insert.
The sides at the top are about 1/4" thick, but flare out starting at the middle
and moving downward.
I need to make the hole for the insert 5 1/4" to 5 1/2" deep to provide the proper recess. I am having some challenges.
1. Bits really are not that long.
2. Forstner bits are not that long And that includes their point.
3. Spade bits are almost that long. I can put an extension on then.
Challenges.
Using a progression of bits, I can almost get the hole as deep as I want, but I have to use some longer tools to deepen the hole. This is interesting because getting the shavings and dust out, to test the insert, is not that easy.
I am getting wobble after making the hole and I can't seem to reset the blank so that it is flush in the chuck so that it does not have some sort of wobble. The wobble creates a problem in finishing and parting the bottom from the blank. And any final cuts.
I've tried using a deadhead live cone but since the sides are around 1/4" at the top, I can't use too much pressure.
When I prepared the blank, I cut a tenon and shoulder for the chuck to mate against. The tenon is about 3/4" long and the should about 1/2" thick.
OK, question. What are the suggested approaches I should use so that I don't get the wobble?
