Lesson Learned
Dale Bonertz
I have done quite a bit of coring with the Mcnaughton tool. I have worn out and I have ruined blades. Inevitably it is large honey locust when I ruin a tool. At the transition point from the side to bottom, where you start cutting into end grain, is where the catch wants to grab. I will no longer core honey locust using the jumbo blades (the only ones I ruin). All other blades seem fine but the density of honey locust and the resultant stress put on the jumbo blades is just to much. I have been successful with honey locust and the jumbo blades but also have ruined to many blades - just not worth it. BTW I have the tool height adjusted correctly, I have played with many different speeds and rate of entry, opened kerf (made it worse), waggle method and etc. Some woods just don't want to be cored when they are that big and dense.
Lesson learned, anyone else have a lesson learned to share.
