moving heavy machinery
Over the last few years I have been upgrading the machinery in my shop. Upgrading to more professional gear usually means heavier. I have been re arranging things in the shop to fit some of this gear in and moving it is a real bear for one person.
Do you all have any tricks you use. The ideal thing would be a big sturdy A frame with a lift of some sort but alas there isn't any way I have the room for something like that. same is true for an engine hoist.
I was able to move the table saw by lifting one side and kicking a pipe under it. Then the same with the other. roll a little and move a pipe. Worked pretty well but was a hassle.
the new metal working drill press was a real bear. tilted it a little and walked one corner around. Then tilted it the other way and twisted. Managed to walk it across the floor like this but if it had gotten away from me when tilting it would have gone down and I couldn't have stopped it.
Fortunately the new bandsaw has it's own wheels but getting the thing off the 485 lb thing off the truck was really a challenge. I built a block and tackle system out of my old repelling rope and some carabiners and was able to push it out and control the slide off the truck.
Eventually going to try and get everything on wheels of some sort so when I have to move I can just roll it in the truck.
Re: moving heavy machinery
Bill Howatt
I don't have any magic solutions but I have a couple of about 16" square dollies with fairly small casters. With some help it usually isn't a big deal to tip whatever enough to get one under a side then rotate to get the other under the other side. Of course if it is heavy you do need help and when dealing with heavy objects you shouldn't be trying to do it alone anyway.
For getting heavy things out of a pickup, van or SUV, I have a long-tongue (used to be boat) trailer that has a plywood deck. With the tongue on the ground the back end pretty well matches the height of the vehicle. Put a hefty person or 2 on the tongue (has huge mechanical advantage) and then slide the object out and onto the trailer. Wheel it away then tilt tongue end up to slide it off the trailer.
Bill
Lyle Jamieson
Lyle Jamieson
Use leverage not muscle. A lever and a block is all you need to move the world. Use a crow bar or lever of some kind. With a block up close to the weight and any kind of lever...even a 2x4 you can lift an enormous amount of weight. Lift it in small increments and place blocks under it til it is far enough off the ground for your pipes or dolly to roll it across the shop. Then reverse the leverage on a block to remove the wheels and set it back to the ground.
Ric Taylor
Ric Taylor
When I need to move my heavy work bench I use furniture castors. Each castor has three swiveling wheels and will support 300 pounds. I use the jack from my car to raise the bench an inch or so and slide a castor under each leg. Then the bench can be wheeled around as necessary. Thankfully I don't have to do it very often.
Ric
Mike Stafford
Don't underestimate the use of.....
Mike Stafford
MAGIC! :b :D
Just put on your ruby slippers, click your heels together and say "There's no place like home, there's no place like home."
That's all I have to say about that. :|
Dick Hines
Re: Don't underestimate the use of.....
Dick Hines
John, the best way I have found to move heavy things is to talk some else into moving it for me. A couple of cold beers sometime works :D
Keith Newton
I have a 2 ton engine crane from HF that I got when building my big lathe. It wasn't very expensive, maybe $150 back then. The feet fold up, and the crane arm folds down, to where it only takes up about 2.5' x 2' of floor space.
It is surely handy getting heavy equipment up onto a trailer, or truck bed.
To move things around in the shop, I only lift things high enough to slip a couple of 2x8s across the feet, then let the tool down to rest on the boards. This stops the swinging, and lowers the center of gravity while I drive it around.
It isn't the kind of thing I need very often, but surely nice when I do. You might talk to some of your other shop friends to see if any want to go in on it with you.
It is really nice for mounting hunks of wood about the size of a #3 washtub on the lathe too. Just pump it up, roll it over, set the VFD on real slow, and let it thread right into the faceplate.
Half the fun is figuring out how to move things myself. If I ever get to build a shop it will have an I beam running down the middle with a dolly on it
Harry Robinette
Harry Robinette
John
I'm with Lyle on this one I'm 62 with two bad knee's and my lower back is almost gone. I just moved my 500
# Vega about 9 feet with nothing but a lever, block and small dolly. I put my band saw 380# on a mobile base with the same lever and block.
Lever and block can move the world as they say.
Dennis in Southern Oregon
John, I don't have a specific recommended technique beyond what has already been mentioned, but you might mosey down to your local tool/equipment rental establishment and see what they can offer.
Dennis
jim miles
jim miles
Try rolling it on lengths of pipe.
Once saw a 75 year old metal worker move a 500lb piece of equipment that 4 young guys couldn't move- on pipe lengths
Josh Bowman
I bought an engine lift from Northern for about $150. It folds up, but still is kind of in the way. It does and excellent job though.
I also use 3/4" heavy wall plastic pipe. I used them to move 1000# gun safe and my Jet 22-44 sander and many other things.
Another trick I use was taught to me from the wood stove folks over in Cookville, TN. If you have a load in your truck or trailer, lever some long 2x8's or 10's under the load and with the 2x's sticking way out from the bed, simple push them down and the load will slide. You'd think it would come down quick, but you'll be amazed how much control you have by just lifting them back up and the load stops. I used that method of course with a 600# stove and my PM66 table saw as well as my big band saw.
To raise things up or down, I use as flat bar and some scrap 1x's or 2x's and go to one side then the other levering and stacking or unstacking. I used that method to get wheels on my bandsaw, drum sander and heavy Walker Turner DP.
I have a 5' bar that I use often. I raised the bandsaw and put it on 2x4's but u think I need to put 4x4's under it.
Here's my method
Jennifer Indy.USA
A cooler full of good beer and and a handful of friends usually does the trick.
:D
Enough beer and the current location looks
Dick Coers
just fine. You can always move it latter.
Re: Here's my method
Bob Edwards
I'm with Lyle and Harry. Any pro rigger will reach for a few blocks of wood an a lever before anything. For some things they block one end until they can get it on rollers and use a mule to lift and move the weight from the other. A"Mule" is nothing more than a lever with two wheels at the pivot point. It is a lot less expensive than a pallet jack!!
phillip Medghalchi
John, if you know how to weld you may want to look at this link and you may know the guy anyways. but I think if you have the bottle jack then you can make this. When you go to this page look for Stubby Lathe lifter title. good luck.
http://www.ttit.id.au/gadgets/gadgets.htm#Dust
John lucas
I have wheels for my lathe that I install with a hydraulic car jack. I've been thinking about making a sort of angled tongue to go on it so it work like a mini fork lift to lift things that sit too close to the floor
Re: ++ beer and 20 somethings
Re: but seriouosly
Bob Entwisle in NJ
I've moved a lot of heavy stuff with levers and blocks to raise it up enough to slip a dolly under, and then then levers and blocks to get it off the dolly.
Bob in NJ
Re: but seriouosly
Yea the fun ones are my new metal working drill press. It's really heavy and very top heavy. Was afraid to tilt it enough to get anything under it. That's why I walked it like the statue shown in a post above. Even then I thought it was risky. It could have used a much larger base but then it's an off brand so I guess they were saving money wherever they could.
Re: but seriouosly *LINK*
Bart Leetch
I haven't got a shop right now but I know what I am going to use when I move into a new shop.... 1963 model 444 Bobcat may not be fancy but sure takes a load off my back.
