'Travel' Lathe
'Travel' Lathe
'Travel' Lathe
Ron Solfest
I've just retired :) and plan to take advantage of the opportunity to pull our Travel Trailer (and 5er in the future) around the country more. I'm thinking about getting an electric chainsaw and more portable lathe than my PM3520b to travel with at campsites. It would need to run on 110V and be able to manage in/out of the trailer (I'm thinking I might be able to rig up some type of water ballast. I'd like to be able to turn small bowls and boxes, and whatever else strikes my fancy.
Would love to hear from others that might do this, or have recommendations.
Thanks,
Ron
Ps - don't have a lathe with me in our current trip to TX, but am bringing home a few logs of mesquite and post oak from two of the campgrounds we stayed at :)
Re: 'Travel' Lathe
Re: 'Travel' Lathe
Dick Coers
Tough to beat the Jet minis. 1015 evs at 82 lbs, or maybe the 1221evs at 137 pounds. All Jet are 15% off from Feb 28th to March 10.
Congrats on the retirement, I just joined that club myself!
Re: 'Travel' Lathe
Mike Peace
Re: 'Travel' Lathe
Mike Peace
You have to carefully evaluate a little more HP and the 12" swing against the lighter weight of a 10" like the Jet 1014 that you are going to schlep in and out ofr your trailer on a regular basis.
Re: 'Travel' Lathe
Re: 'Travel' Lathe
Gerald Klug
I have the jet 1014 VS for traveling. It is light enough to haul around but I could be talked into a 1221 really easily for the greater power and reverse. .
Re: 'Travel' Lathe
Re: 'Travel' Lathe
Dale Bonertz
Jets are nice lathes. I had a 1014 with VS but for bowls it's minimum speed was 500rpm if I remember correctly. That was a little to fast for small bowl turning when returning dried blanks or out of round stock. I would consider finding one with a lower minimum rpm for your travels. Good luck.
Dale
Re: 'Travel' Lathe
Re: 'Travel' Lathe
I replaced my jet and Rikon with the Delta 46-460. More power a d variable speed but at 100 lbs is a little awkward to carry. I put quick release knobs on the stand so it all fits in the trunk of my car Its a little tricky lifting it over the trunk lip.
I thought the jet 10" lathes were too underpowered but the weight of the beefier minis could be a killer unless you have a good way to easily get them out of the vehicle
Re: 'Travel' Lathe
Re: 'Travel' Lathe
bowlman
I'm with John Lucas. delta midi VS. I purchased a Craftsman Gravity Lift Table/Cart to mount it on. A piece of phenolic resin plywood from rocklers makes the table top. Four bolts hold the lathe in position. When I need to take it somewhere, I lift the lathe off the phenolic resin and into the van. The gravity lift table collapses down and can be wheeled in right beside it. The reverse process is so easy. Can do it right at the van and then just wheel it into the site like a 2 wheeled hand truck. Pictures will follow.
