What's your favorite turning "Accesory"
Steve Criscenzo
I had some down time in the shop this weekend (waiting for filler to set) and I used some of the time to clean and organize. As I moved things around, I realized that I have a few accessories that I am really glad I have and there are some that are never used.
If you had to pick a favorite accessory in your shop, what would it be.
My definition of "accessory" - I did not really need it, maybe a bit of a luxury. I could do most of what I do without it using different methods. I took cutting tools (gouges, scrapers, skews ...) off the list as well as scroll chucks.
My short list came down to two items. First was my vacuum chuck system, I use it all the time and it works so well. My second item was the tilt down system that rolls the tail stock off the bed. (I have the one that was sold by Robust for the PM 3520B for a while). This was definitely a "didn't really need it" purchase and I only decided to get it because it was heavily discounted but I find I use it quite often especially now that I have to make room for my accessory router table. It has also helped my back by allowing me work off the end of the bed and thus not have to bend as much.
How about you folks. Anything you care to share.
Steve
PS It was nearly 70 degrees in Durham, NC today. Worked with the shop doors open for the first time in a long time. Hard to believe a week ago we were dealing with snow. Longing for spring!
Re: What's your favorite turning "Accesory"
Brad Vietje
Air Compressor
Brad Vietje
Compressor: Many would consider this an essential item, and not an accessory, but I've been turning without one for the past 4 years and I really miss it!
I had a nice, older one on wheels that was broken about 4 years ago during construction of our new house. I hit a 2" stone while pushing it a bit too fast, and it stopped very suddenly, and I went right over it, resulting in a nasty little cut across both shins (and gravel embedded in both hands), and all the brass and copper tubes and fittings were broken and mangled. Since then it has been buried in the barn, an I need to dig it out and resurrect/rebuild it. Have not been able to afford a replacement.
As someone who occasionally turns lots of hollow forms with pretty small openings, I really miss it for getting the chips out !
Safe spinning,
Brad Vietje
Newbury, VT
I made myself a thickness caliper for bowls. Looks like a giant par of scissors except the blades are curved into a circle with the tips touching. The pivot is in the center lengthwise, so you can look at the handle and see how thick the wall is. And when the tip are closed, the inner edges of the handles are flush. You can slide them along he wall and very accurately tell where it is thick and thin. Somebody swiped my first set and I made new ones immediately.
Compressor
Jorge
Like Brad, I miss my compressor, it went south on the fall and have had no time to revive it, or get a bigger one.
Emmett Manley, Lakeland, TN
Drilled golf balls on my Oneway live center. I use the balls for jam chucking and, when double drilled, as a custom tailstock support system.
Also, if you keep a golf ball on your pointed live center, you won't poke a hole in your elbow.
Dick Hnes
Compresser for me too. The one I had was 5 years old snd got a lot of hard use. I had a new one in less than a hour. I wanted a larger one but did not have the time to do the new wireing so went with a 120v one.
Steven Antonucci
my least favorite was the steady rest.
Steven Antonucci
So much so, I took it apart.
A compressor is almost compulsory. Same as a chuck in my opinion. Or a chainsaw. Turning without them would be expensive and time consuming.
As far as my unnecessary accessory... it's my Tormek. You don't need one, but you'd have to pry it out of my cold, dead hands to make me give it up. I am on stone #3.
Steve
My brain
I don't need a compressor it's nice. Don't need my vacuum chuck but sure is handy. Don't need chucks. I can sharpen with just about anything that has grit. Chainsaw nope used to use a bow saw to cut my blanks. Sandpaper may be the one tool I can't do without
Re: My brain
ron bauer
I have convinced my wife that I absolutlely need everything in my shop. I sure don't want to change that! Believe it or not, I probably could not get along without some kind of wall thickness gauge. I used to make a lot of funnels before getting one.
tool handle
Dale Bonertz
My Kelton ER collet tool handles. Not the hard plastic type that comes with the coring tools but the newer type that he was trying to sell. They came in ER32, ER25 and ER16 with the correct length for each. They have a softer foam rubber on the handle and switching to a sharp gouge is a simple twist and turning again. Makes sharpening gouges so much easier without a handle. You have a stack of gouges without handles which are easier to deal with. Makes me much more efficient with my turning time. Just love these handles.
Re: My brain
Steve Criscenzo
John
Do you really consider your brain an accesory. Seems like it goes in the standard equipment category. You must have something in your collection of toys that is just cool to have.
Steve
I say my brain because
One of the things I enjoy most about woodworking and turning is coming up with ways to accomplish things. Could be as simple as taking 2 jaws off your chuck so you can turn off center work or as complicated as making a new tool. Figuring out how to turn something after you've designed it is most of the fun for me.
Of course the other fun thing is all the great excuses we come up with to convince ourselves we need a new tool or gadget. I was telling my son about my new bandsaw and giving him excuses for buying it like I was married to him or something. Cracked me up. He doesn't even live here anymore.
I also say the brain because I look back at some of the turnings I did 15 years ago and wonder how I did them. I certainly didn't have the skills I do today. However I was determined to build them and came up with the solutions. Some I still don't know and would probably come up with different solutions today.
Wayne Kuhn
Automatic center punch.
Chainsaw & Bandsaw
charlie belden
FREE WOOD seldom comes as suitable sized blanks for my little JET Mini VS. Without a means of converting a logette to suitable size, FREE WOOD is just something to stack and move around - or maybe burn in the fireplace, assuming it isn't a No Burn Day - a concern when you live in a valley with a million and a half other people - which is what Silly Cone Valley is.
But if you've got a chainsaw you can cut up just about any size piece of a tree into more managabe and suitable turning blanks. And THAT means not only more wood to turn, but more types of wood - especially if you've got tree trimmer and arborist friends.
Now a chainsaw is a great "accessory" that lets you convert unusable wood to turning sized rough blanks. A chainsaq,however, is NOT a finesse tool - at least not in my hands : ) and it's LOUD and it's not easy to use it to cut close to round blanks. THAT's where a bandsaw "accessory" fills a much needed NEED - especially if you've only got a Mini lathe and a chainsaw.
Bandsaw for sure!
Don Orr
I could make do without a lot of the little do-dads but my bandsaw is definitely my favorite "accessory". I finally upgraded to the Carter guides and wish I hadn't waited so long.
If you like the Carter Guides . . .
charlie belden
check out Laguna Tools' ceramic guides.
Re: If you like the Carter Guides . . .
Ditto I don't like the Carter guides for green wood. The bearing get stuff clogged all over their surface and I have to clean it off before I can do any other work on dry wood. I prefer the traditional guides for that.
