Routed Rim #2 - Stopped Groves
Steve Criscenzo
Played some with routing stopped groves in the rim of a bowl. The bowl is a walnut about 12" in diameter and 2" high.
I cut the wide grooves first and filled them with black Inlace with brass powder added. I did not keep it mixed well enough while pouring and ended up with some variations in the density of the brass. (I was tempted to toss it when that happened but since this was a test on methods of work I decided to keep on.)
After the filler in the wide grooves was set, I remounted the bowl and cut the narrow grooves. The narrow grooves are filled with clear Inlace with brass powder.
I used my index wheel to stop the grooves. Instead of the index pin going into the holes on the wheel, I put small bolts in the proper holes on the wheel and used the index pin on the stand limit travel between the bolts. The set up is shown in photo 2.
The third photo shows a detail of the grooves. The narrow grove is only 1/16" wide. Because the wide and narrow overlap with tight tolerances, the proper alignment of the two groves important. The cross feed vice has index marks to 0.001". By recording the measurements while cutting the wide grooves, and then repeating those measurements after remounting to cut the narrow grooves, I was able to get it pretty much dead on.
Still a work in progress but it has been fun to play with.
Comments and suggestions welcome.
Steve
Re: Routed Rim #2 - Stopped Groves
Steven Antonucci
Looks pretty good?
steven antonucci
I know that from conversations with Harvey Fein, this is very hard to do very well. The tolerance and play in each area need to be exact, or the end result will be sloppy. It looks like you've figured it out...
Steve
Keith Tompkins
Keith Tompkins
I like it! Lots of potential here :D
Josh Bowman
Steve, I think you have something here. I really like the look.
Dick Coers
Personally, I would like to see smaller grooves. To me, the grooves do a lot of shouting, and make your eye ignore the rest of the piece. Smaller grooves would be more subtle. I like this piece more than #1.
Re: Smaller Groves
Steve Criscenzo
Dick
I agree with the smaller grooves. Based on feedback on No.1, I went from a 5/16 to a 3/16 bit for the larger groove.
Thanks for your comments
Steve
The jig  & router
Jimmy Edwards
Where did you get the jig and DeWalt router. Is there also a jig for holding the router vertically? Thanks
Re: The jig  & router
Steve Criscenzo
Jimmy
The router is a standard Dewalt trim router. I used a metal working crossfeed vise that I have had for years. The rest I made myself. I posted pics about a week ago. Search on my name and you will see the thread.
SteveSteve
Re: Smaller Groves
Steve don't know if you remember but I made two other router jigs hold my router at 45and 90 degrees so I could change how the bit cuts and use some metal cutting milling cutters
Re: Smaller Groves
Steve Criscenzo
John
I remembered your platform but did not remember your angled approach. I will go back and look. How did the milling cutters work on wood.
Steve
matt overton
Steve, have you looked at Eli Avisera's jig that is sold through Ligno tec? you have recreated a lot of what his jig can do at a fraction of the cost.
http://www.lignolathe.com/en/compound_slide/index.htm
Re: Smaller Groves
They work great. I use mostly the 90 degree cutter for cutting the flutes on my cupcakes but did play with a ball end cutter one day and it seemed to cut cleanly.
Re: Smaller Groves
ron bauer
Regarding endmill cutters. I am a prolific user of endmills and carbide tooling for turning wood. A couple things to remember in this regard. Buy tooling specified for aluminum, brass, etc. aka "non-ferrous". This is because they are much sharper than that spec'd for steel. The ones for steel actually have the sharp edge broken (dulled) to extend their life. This also pertains to round carbide cutters. I also prefer the two flute style end mills. This is IMHO.
Steve Criscenzo
I had not seen his system before but it seems like a similar concept. I bet mine is more stable just due the base and mass of the vise. Mine is likely not as versatile though. (the more adjustments, the more pivot points, the more potential flex)
I did not see a price. Do you know what it costs.
I did not spend anything to make mine because I had the parts on hand but even if you started from scratch you could do it for about $125 plus the router.
Steve
