Trying something new...(with success...and not)
Steven Antonucci
steven antonucci
Here is a bowl I finished over the weekend, with some "notes" on how I did some things, and what worked and what didn't:
For starters, this maple bowl was roughed out at least six months ago, and left to dry with a wider, thicker band at the top. The intent was to make the band form handles, and the second turning of the outside of the bowl actually did not go all of the way up to the rim. The last inch was carved away on the lathe with a drawknife and spoke shave. (I'm going to say that this worked as planned)
The interior was twice turned to be round inside, sanded to 220 grit, and then finished with lacquer to hopefully seal against the milk paint staining any drips or issues. If you look very closely, there is one spot that has slight oxidation after steel wooling the rim to remove the drips and over-painted areas. (I'm going to take credit for this "working too")
On the outside, the bowl was textured with a ballpeen hammer over the course of a couple of hours, and then painted yellow and then blue. The idea was to have an orange peel like effect after steel wooling the milk paint to a sheen. 10,000 hammer blows for nothing. (did not get what I wanted, calling it a fail...) I also think that my brush strokes are very obvious, so I will pay more attention on the next one. I carved the bottom with a shallow gouge, and it is much closer to the effect that I had hoped for in the hammer blows, so the next one will likely be carved instead of hammered.
Comments welcome.
Steve
Re: Trying something new...(with success...and not)
Quite fun Steve. I did a hammered bowl many years ago for the helmet on my viking piece. I made a ball to put in my vice and then put the wood over the ball. That let me hit it harder making larger dents. Painted it with copper paint and it looked pretty much like a hammered copper helmet.
I screwed up 2 bowls yesterday. Got one too thin near the bottom and when I reversed it on the vacuum chuck it popped the bottom out. Haven't done that in many years. The other one just wasn't cutting clean but I finally got the back side turned. When I turned it around it just wouldn't line up. Not sure what I did wrong but no matter how I adjusted it the rim wobbled badly. Maybe it moved, I didn't check. I was already having a bad day and this bowl was fighting me and I decided I just didn't need the aggravation so I pulled it off and hit it with the sledge. Made me feel much better and I had a good evening. I'll burn it today. :)
I think I was having a bad day and tried to turn to lighten it up and should have done something else because turning didn't work this time. :)
Steven Antonucci
Hammer first, methinks?
steven antonucci
I may try again at some point with a hammer first approach, then cutting the inside out? This bowl was 1/4" below the rim, and I was afraid to hit it too hard... 9,999 good blows+ 1 bad blow= splitsville.
The folly of what we do...
Steve
Re: Hammer first, methinks?
Mine was very thin that's why the block was underneath. I got a few really small cracks but that kind of added to the character of the hammered copper look.
Brad Vietje
Question on the Hammering
Brad Vietje
Love to see folks trying something new -- especially if its something I want to try someday, too!
I've been wanting to try some faux hammered copper turnings, and wondered about how those compressed "dents" would respond to changes in relative humidity ? For a decorative piece probably one answer, but a utilitarian piece like a bowl might have a different answer, no? If it was used for salads or other "wet stuff" I expect it could take on more internal m.c. (?)
Would like to hear (read?) about the experience of others who have tried this.
John -- did you wear your Viking helmet in the rain ?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Question on the Hammering
Brad Humidity won't change it. Now if you wipe it down with water your in trouble. Of course on my helmet the paint should keep the moisture exchange to a minimum.
Fertility Experiment #29
This is what the helmet is all about. Horns and helmet are all wood.
Keith Tompkins
Re: Fertility Experiment #29
Keith Tompkins
One of your coolest pieces ever!!!!
phillip Medghalchi
John, I thought I was the only oe having bad day last Thrs. when I screwed up three 95% finished bowls in one day. I guess ther some days that are not meant for turning huh? :\
phillip Medghalchi
John, I love that concept. I don't want to hijack this thread, but can yo make a new thread and share how you did that hammered look on that piece, please?
Bernie Rose
Beautifully done, John but at you age you shouldn't be giving obeisance to the fertility gods.
Phillip. I used a hammer. :) On this piece it was pretty thin after turning the bowl. I turned a dome shape on a piece and clamped it in a vice. then I put the bowl over the domed form and simply hammered using a ball peene hammers rounded end. It took a few hits to find the right hitting pressure. To little and it didn't dent, too much and it made a tiny crack. It varied somewhat due to the density of the wood so you kind of had to learn the feel. The good thing was if you mess up you just hit it some more to change the dent. Not hard to do at all.
I haven't tried what Steve suggested and that is hammering it before you hollow. I think that's a distint possibility. It would work especially well for texturing a raised bead area so it would look like a metal band. turn the band approximately to shape. Hammer it. Spray it. Then finish turning to clean up the overspray. I'll have to try that in the next week or so to see how it works.
