What kind of scale
What kind of scale
What kind of scale
phillip Medghalchi
In another thread about Moister contect of the wood measured by Moisture meteres(Ron Bauer); so I didn't wan to hijack his thread, most of you folks replied that you don't use MM's. ok, from the replies it sounds like most of you weigh the blanks. So, what are you using for weighing. I tried to find scale that is capable of weighing 10lbs or more and they are expensive, so what do you guys use, and how often you go around your shelves and pick up the blanks and weigh them and record them?
I am trying to figure out the practicality of this. do you really record the weight?
Re: What kind of scale
Mike Brazeau
Starfrit make a digital kitchen scale that can read 1 gram resolution to 5kg and and can also read pounds and ounces if you want to complicate things. Sells in Ontario for as low as $10 on sale. I have been using for several years. Also have a old high capacity spring parcel/postage scale that goes to 20 Kg reading divisions are 100 grams. I write date and weight on the roughed Bowl or spindle blank and monitor whenever I think of it. When weight is reasonably constant, your blanks is dry. Also lets me know how long I have had rough outs around.
Bill McWhirter
Check eBay for postal scales. For under $20 you can get a digital electric one that measures up to 80 lbs. or so with an accuracy of 0.2 oz. which is close enough for our work.
I weigh rough turned pieces, re-weigh occasionally and write the weight and date on the piece itself with a pencil or sharpie. When the weight stabilizes for a month or two, I feel that the piece has lost about all the moisture that it is going to. I personally use the metric system because it is easier to write 640 on the piece than 1 lb, 5.62 oz.
I don't weigh very often. Most of the time I put rough turned bows up and it's 6 months or more before I get back to them so they are all dry. I use my standard bathroom scales for most average to larger bowls. They don't have to be accurate just repeatable since all we really care about is when it stops losing weight. On my old scales they weren't very good below 10 lbs so I put a 10 lb weight on it and then weigh the bowl For smaller pieces I i use some digital scales I used to use for mixing photo chemicals.
Dick Hines
Dick Hines
I soak all my bowls in denatured alcohol. Then wrap them is brown paper. then they are put in the unheated side of the shop out of the sun. A 14 bowl with 1 1/2" walls will be dry enough to re turn in 2-3 months. Depending of the type of wood.
Never weight them before I return them.
Harbor Frieght... *LINK*
Ralph Lindberg
...your source for disposable tools
70 lb scale
Bernie Rose
I use a postal scale from Staples.
