Router Mount Version 2
Steve Criscenzo
I posted my original router mount a few weeks ago. After using it and receiving a few suggestions, I have made version 2.
The major changes are, the cross feed vise can now rotate relative to the face of the turning and I made the mounting for the router much stiffer.
To allow it to rotate, I made a circular base that included two slots for the hold down bolts. I added a third track down the center of the table with a corresponding guide rail on the bottom of the circular platform. This assures rotation about a constant axis and allows for much easier adjustment. The first photo shows the underside of the base. (Before I took it apart I used the Version 1 system to make the stopped slots in the round platform.)
I eliminated the plastic from the router mounting assembly to the vise to reduce flex. I had some 3/8 thick aluminum channel that I cut to make the angle to attach to the vise. I used 1/4 aluminum plate to attach the router base to the angle. It is now very stiff and I do not think there will be flex when using.
The second and third photos show the front and back side views. The last photo is a detail of the router mount assembly.
It will be a week or two before I get a chance to give this a go. I will post results.
Steve
