Veritas - Innovation in Tools
Mounting Green Wood Bowl's
Tom Minehan
How do you mount bowl's for finish turning that were turned from green wood and placed in paper bags for drying? We know they will be/are warped, including the spigot or recess.
I scored some maple and ash this summer, turned some green bowls and dried them in paper bags. They are now dry enough to finish turn but I can't deal with the wobble. I never gave remounting a thought. How do you "true up" what ever you are going to use for mounting them in a chuck? The blank's I have used previously were dry enough to turn in one session?
Re: Mounting Green Wood Bowl's
Don in Central Illinois
Use a jam chuck and return the spigot to round. Use a chuck and then true up/return rest of bowl.
Very Carefully.....
There are many ways. One way (Assuming you have a chuck) is to mount them with the rim of the bowl toward the head stock with the chuck in place and the jaws nearly closed so you have a round circle. Bring the tailstock up gently and then check to see if the rim of the bowl is fairly true and centered as best you can. I use the tool rest as indicator. Put the end of the rest even with the rim of the bowl and turn the bowl. The bowl will be roughly an ellipse. Move the bowl around by moving the tailstock until you get it as nearly balanced as you can. You need the tow long points of the ellipse to be equal distance form the tool rest and the two "short" Points as well. So when you start this you start with the tailstock barely holding the bowl. When you find the sweet spot, tighten it firmly and turn a chuck foot. You need to know what the limits of your chuck are to turn the foot. You can turn a spigot or a recess. Start with the lathe set at a slow speed. Once you have a foot, you can reverse the bowl and turn it.
PS....
The warping of the bowl will to some extent determine the wall thickness. If it is very elongated you may end up with a very thin bowl. You can check that by measuring the two dimensions of he ellipse.
Henry (Raleigh NC)
Tom: I found myself asking the same question not so long ago. The advice I received here only helped once you know it at the green turnig stqge - but here it is.
When you create a tenon on the green bowl - immediately create a small dimple in the center. Assuming you have a blanced piece (and not overly stressed limbs for example) the dimple remains in the center of the tenon even as the tenon becomes elliptical. Once dry, mount the bowl with a jam chuck in the headstock and a live center in the tailstock. The bowl "centers itself" and you can easily turn the tenon round again (assuming there is enough wood on the tenon to create a round shape that your jaws can grab).
Hope that helps
Henry
Harry Robinette
Harry Robinette
Tom I do mine just like the others have said. I make my tenon just a little less then the max of my chuck,I've never had a bowl warp to a point I couldn't cut a new tenon.
Adrien
As a very rank amateur, I've had the advantage of just putting the tenon turned green into the chuck and returning the bowl. Out of very many bowls I've only had one too oval to be able to return. The preceding turners must have much more elegant finished products than mine, but the salad tastes the same.
phillip Medghalchi
Tom, all of the above are excelent points. Also, when you green turn your bowl you need to kind of picture what thickness your final piece is going to end up to be, so you can plan accordingly and also, as mentioned above at this stage make sure you do not cut your foot tenon too close to the minimum capacity of your chuck jaws. It's better to be close to the maximum capacity of your chuck jaws so when optimally dried and distorted or warped you still have enough meat left on the foot to turn it round again to be able to rechuck it to proceed to your final turning.
Brad Vietje
Brad Vietje
I reverse them over the chuck with the jaws opened to their widest, for better support. Another method is to use a disk of wood held in the "wood-worm" screw to drive the opening of the bowl, with the tail center supporting the foot.
Like others have written, it is best to keep the mark left by the tail center from the first mounting, so it can be readily centered again.
Consider turning the entire outside profile of the bowl -- including sanding and finishing -- while you have it held between centers, before flipping the bowl around and mounting on the tenon (or recess) you trued up. If you use a disk of wood almost as large as the inside diameter of the bowl rim (held by the chuck or a faceplate), you will have better support between centers and less vibration than once you have it held by the chuck alone. If you mount it between the tail center and the chuck with the jaws closed, you won't have very much support, so just true up the tenon, and use it to finish turn your bowl.
Safe spinning,
Brad Vietje
Newbury, VT
Philip F Duffy
Do what Brad sez. P.
Jeff Smith
I've found that even with woods that move a lot, like Madrone, the tenon is rarely warped so badly that it can't be safely gripped long enough to turn a recess inside. The inside recess provides a good hold to re-turn the tenon and shape the outside of the bowl. Slow speeds and tower or shark jaws on the chuck help here. In the rare event that the blank did not warp relatively symmetrically, a jam chuck helps.
One thing I have found helpful is to face off the rim when turning the recess and establishing just how much wood is left when the form is round again by turning the rim's outside and inside limits to round. It only needs to be 1/8" or so from the faced-off rim surface to determine if there's enough wood left to turn into a bowl or if the height needs to be adjusted to compensate for warping.
don stephan
One possible drawback to finish turning the oustide without a new recess or tenon would seem to be if the need arises to remove the blank for some reason before completion, or if the blank somehow would shift during finish turning. It might be difficult to remount the blank exactly the same. If the first step is to make a new gripping method, either a recess or a trued tenon, the blank could always be remounted almost exactly the same.
