20" sanding disk
20" sanding disk
20" sanding disk
Dave Staeheli
I needed a larger sanding disk as the segmented rims on my bowls kept getting bigger and bigger and my 12" Jet just wasn't big enough. So made this lathe mounted disk. Started with a 20+" x 1/2" piece of corian cut generally round on the bandsaw. Then bolted it to an eight inch face plate I never used. Then I spun it up and trued the edge. There was a slight wobble, so used a piece of paper as a shim. While not perfect it is better than my Jet. I can use my banjo mounted table if I need to. Purchased my 20" sanding disks from Grainger. Not sure how fast you can spin corian so keep the speed on the slow side. Very happy with this set up.
Re: 20" sanding disk
Bernie Rose
That is why I am happy that I had shop room enough to NOT get rid of my old SHOPSMITH. It is now a dedicated disk sander.
Peter Rand
Dave - How did you go about mounting your control panel on the headstock casing of your OneWay? Is it straightforward?
Mounting Oneway control panel - long
Dave Staeheli
Peter: There was some work involved, but to me, well worth it. I love, love, love my oneway but hated that stupid control arm. Either it kept getting in the way or I never knew where it was. I wanted the control panel handy and my body knew where it was when the stuff hit the rotary impeller.
I drill and tap a lot which an easy skill to learn. Also I'm a bit of a pack rat and happened to have a thick oval pipe flange. The hard part was grinding a groove on the bottom of the pipe flange so it would "seat" on top of the headstock. I drilled, tapped and bolted the pipe flange to the headstock. My stars aligned and a short piece of pipe threaded into the pipe flange just barely fit into the stub pipe coming off the bottom of the control panel. Friction fit. I also cut off some of the stub pipe if I recall. I have know idea where to get another pipe flange like that one and I don't think a regular pipe flange would work. I would guess the best would be a scrap of large diameter pipe with a piece of stub pipe welded on would work.
After disconnecting the control wire from the box and pulling it out of the control arm, I had to find another location to bring it back into the box as I did not want to bring it up from the bottom any more. I chose a location on the back side and simply brought it in through there. I used the original through box protector, a couple of wire clamps screwed to the lathe, a piece of electrical split hose protector and a couple of wire wraps to control the excess control wire. I didn't cut the control wire any shorter as didn't want to commit myself the the headstock mount in case it turned out to be a bad idea. Now think I should have as I never have any intention of going back.
Notice I've tapped in a couple of 1/4" bolts for a chuck wrench holder. Also I've extended the handle of the spindle lock. Had to disassemble that, cut off the tiny knob, thread it with a die, then screwed on a short aluminum handle that I had to turn a bit to clear the headstock. MUCH easier to use.
Re: Mounting Oneway control panel - long
Peter Rand
Many thanks for the info Dave. It looks MUCH more convenient to use.
