Oliver lathe is ready to ship
Wow that was interesting and quite challenging but I learned a lot. I bought a cheap chain hoist and was able to dissassemble the lathe. Then I built the crate and put the bed it. Positioning the motor onto the bed was challenging and there isn't anyway I could have done it without the chain hoist.
Guess I learned my lesson on bidding on something unless you really want it. It was however I think a good experience. I got to learn more about Oliver lathes. I got play with the table saw I bought this fall and figured out new ways to cut up a full sheet of plywood in the shop. That in itself was a good thing because it forced me to re arrange and get more space.
And last but not least. It's almost the perfect size for a coffin if I need to build one. Anyone you want to get rid of. :)
Re: Oliver lathe is ready to ship
Brad Vietje
Re: Oliver lathe is ready to ship *LINK*
Brad Vietje
Wish it were coming to me... I really like those old machines. Oliver made some of the coolest lathes, as well as some of the ugliest!
They are now offering a new model 2018, with a 20" swing and 42" between centers (no idea about the 18 part...?), so they are back in the wood lathe business.
Safe spinning,
Brad Vietje
Newbury, VT
Oliver 2018 Wood Lathe
This new Oliver lathe seems to be ......
JamieDonaldson
.....a combination of new and old school construction, heavy cast iron and electronics. You can't tell much about the actual speed control with 2 pulley ranges, but what's with that rotating lever on the front of the headstock? That looks like a version of a Reeves drive? :b I wonder what the price might be, and at 900 lbs. + the shipping is a big bite!
Dennis in Southern Oregon
Re: This new Oliver lathe seems to be ......
Yep. If you go to the link in Brad's post you will find a diagram and parts list that show that it is a Reeves drive.
Dennis
Reeves Drive
The manual says "the traditional variable speed pulley system eliminates the troubles prone to frequency drives"
Interesting. It would be fun to see how many problems are prone to Frequency Drives. I don't believe very many but obviously they are still kind of new to the market.
Good quality Reeves Drives do require periodic mantenance but if you do that they do last a long time. The cheap Reeves Drives on the other hand are quite problematic.
You also have the biggest problem. If you turn it off at high speed you have to turn it back on at that speed in order to slow it back down. Not fun if you just finished a pen and want to now make a bowl. Frequency Drives on the other hand can simply be turned down. Several Reeve Drive machines I've worked on require you to turn them down to slow speed to stop the lathe. Cumbersome but obviously safer.
walta
No way do I want to turn start a 35 inch out board blank with no tail stock with a 200 RPM minimum speed setting.
Did I miss the made in the USA label?
Walta
