Obviously can't pick it up and set it on scales. Is it possible to weight each end and then arrive at a weight. I can take the motor off and weight it and the tailstock and tool rest but still can't measure the lathe.
The specs on weight and such should be in the owners manual, if you still have it, or you can probably google the model number lathe and find a copy online which should give you the weight and other specs.......good luck John!
If you can break it down into small enough components, the USPS Flat Rate service might work. Of course it could require any oxy acetylene cutting torch, or a plasma cutter - but it might save some on the shipping cost ; )
Thanks Jesper. That's what I was wondering. I'm shipping the old Oliver lathe. Not sure I could even find a manual for it. I got a quote from a shipper but I'm fairly sure I overestimated the weight. Would like to know for sure and of course it if weights less might save the buyer some money.
I may dissassemble the lathe to ship it in a smaller container. It which case I can weight each piece and the container seperately.
I'm guessing this lathe weights between 300 and 400 lbs.
l had a friend and one of his jobs was to check out the weight and measurements of sailing dinghies so it could be registered in its particular class for racing. l often would ride along to help and he would weigh the boat by placing bathroom scales under one end and then the other and assured me it would be the correct weight. Michael
John here in town, at the fish pier they have a scale hanging from crane, it has a hook at it lower end and then a stack of fish boxes in a sling gets hooked to that and they raise the scale a little, you get the gross weight, deduce the tare weight and bingo! you have the weight of the goods. I bet you can find something like that at a rental place.
You can weigh each end and add the them to get the total. However, for high accuracy you should have a narrow support under each end, ideally a knife edge, and be careful that the supports are in the same places under the lathe for the two measurements.
They have to know the exact weight for truck loading. You can estimate it for a cost estimate, but they are going to weigh it at the terminal for a final shipping cost to you and for their loading.
A hanging scale with an engine hoist...if you don't own these, and can't borrow them, then forget the suggestion, 'cause they'd cost more than the shipping.
Because I will need to move all these tools sometime in the fairly near future It would sure be easier if I can just pick them up and set them on custom wheeled pallets so I can roll them in the moving van. Also would be handy to get logs in and out of the truck.
No plans currently but there's just nothing really holding me to Cookeville. Many friends have moved off and my lady doesn't live near here and doesn't necessarily need to live where she lives. So it's all up in the air right now and probably for the near future but I'd like to move toward Chattanooga to be a little closer to my parents.
When I bought my Smithy Lathe/mill the guy loaded it into my truck with an engine hoist. I had a heck of a time unloading it. Many machines will simply be put on wheels and rolled up a ramp and won't need to be lifted bit it seems like I'm always having to lift something very heavy and I'm not as young as i used to be.
I'd test the method of measuring each end and adding them by placing some known weight -- say a few bags of sand or buckets of paint or drywall compound -- across a 4' length of 2x8 and try it.
I seem to remember from a physics class long, long ago, in a galaxy far, far away, that your weights won't add up to the correct amount -- they should be a little too high when combined -- but I can't recall how to do that anymore!
You could use straps to create a sling, and use a long lever and a fulcrum at a known distance -- say an 8' long 4x4 with the fulcrum at 2', giving you 6' and 2' or a 3:1 ratio -- and figure out the force to lift it with your bathroom scale and multiply by 3 for the total. If you can figure out the mechanical setup, that will give you the exact answer.
Since the two ways I could imagine doing this would involve a force downward on the long end to raise the lathe on the short end, it would be easier to use a hanging spring scale like that used to weigh fish... You could stand on the scale and noticed how much your "weight" changed as you pushed down on the lever (the force would be subtracted from your weight, as your apparent weight was transferred to the lever, leaving less of your weight pushing down on the scale), you'd still get the answer. Say I weigh 195#, and I push down with sufficient force to lift the lathe that the scale now reads 95#, the difference is a 100# force, X3 (for the lever ratio) = 300#.
Obviously, as an endurance athlete in great shape, you would weigh less and would need a longer lever! Maybe a 10' beam to give you a 4:1 ratio, leaving the 3:1 for those of us who are a little chubbier
I've decided to dismantle it and and build a small crate to ship it in. They will weigh it at the terminal for exact weight. The reduction in size and being able to stack light containers on top will also help reduce the cost according to the lady I talked to this morning. Now just have to rig up a pulley system using my porch beams to get the headstock off and lift the ways so can remove the legs. Should be a piece of cake. Of course it's very cold out there so it might take a while. At least I don't think we are going to get the snow that norther alabama and Georgia are getting.
John, they gave you all the answers you needed above, I hope you can still keep your head clear so you can get it done. I went dizzy just reading all those replies. Good luck.
