More Designing Multi Axis Pieces in Virtual 3D
charlie belden
Multi Axis turning can seem so confusing and appear to be somewhat unredictable - a Hit Or Miss Thing - sometimes the results can be interesting, sometimes they can be - well let's just say "not quite so good".
Two turners I know who are doing terrific Between Centers multi axis pieces are Barbara Dill, usiing her Structured Approach, and Peter Rand, who works more intuitively. Both do primarily abstract multi axis pieces. though Barbara's "Tea Set" series and her amazing Harmony piece are a little less abstract.
The engineer in me puts me somewhere between these two approaches to multi axis turning, leaning more towards the Sturctured Approach. To try and understand the fundamental concepts of multi axis turning that Barbara introduced with her articles, papers and demonstration, I've been working on using Google's free SketchUp virtual 3D program to crreate virtual 3D models to illustrate fundamental concepts of MAT (Multi Axis Turning). With the understanding of the fundamental concepts of MAT, I wanted to develop a means of using SketchUp to virtually DESIGN multi axis pieces. And from the resulting design, I wanted to have
Where the centers on each end of a between centers should be
What the profile on each axis should be
What the results should look like for each step of the turning process and ve able to print that out and take to the lathe to create the piece
I've been able to do all that - first with a multi axis piece I did that conveys the look of my oldest grand daughter Kaitlin. at age 6 - and then with a series of multi axis pieces inspired by a Masai herdsman.
Now I've taken an idea of a multi axis piece that Peter Rand has done which is part of a set of six pieces he titled "Gathering".
In the view on the left, I saw a Maltese Falcon, which led me to this side view image of a Maltese Falcon.
And from that image, which I imported into SketchUp, I developed a virtual 3D model of a Three Parallel Axes, Two Profiles abstract Maltese Falcon.
First, a color coded version to show which surfaces of the piece was created by each axis. Note that the Blue and Green profiles are identical, their axes merely offset from each other.
The colors are kind of distracting, so here's a gray scale version of the same piece, same views
I put together two videos attempting to show how the piece was DESIGNED in SketchUp and uploaded them to YouTube
Here's the first attempt video
http://www.youtube.com/watch?v=sP3Sh9AA00E
I then tried to simplify things and did another video
http://www.youtube.com/watch?v=uyeoz9i5SiI
SketchUp is a powerful design tool, though it does have a learning curve to climb. I'm working on ways to flatten that learning curve a bit to make it easier for turners to use.
Anyway, comments, questions, suggestions for making things clearer, etc. are hereby solicited.
