First try with router mount
Steve Criscenzo
Last week, I posted photos of a router mount I made to allow precision control of the router. Here is the first piece made using the new mount.
The bowl is about 12" in diameter by about 2.5 inches high. I believe the wood is Spanish cedar.
The grooves were cut with a 1/4" bit and filled with Inlace with black dye. It does not show in the photos but there is a bit of metal flake in the filler.
I wanted a clear finish so I applied a very thin coat of CA and then buffed and waxed.
A couple of lessons learned. The wood I used was a bit too open grained so I had a bit a bleed through with the filler. I will either seal the groves or use a tighter wood next time. I had a bit of tear out but I did some trials with a spiral cut bit and it worked much better.
Before you ask, yes I could have cut these particular grooves by hand but this required three different mounts so precision was critical. I also have plans for stopped grooves and some multi step inlays so repeatability is important.
Unable to leave well enough alone, I have the jig taken apart now to add the ability to rotate the base.
Comments welcome
(Sorry about the photo quality, just did a quick take in the shop)
Steve
Re: First try with router mount
Good job Steve. I fill grooves like that with lacquer before filling with Inlace or epoxy. It seals the end grain pores so you don't get bleed through. I've ruined a few piece before I figured that out.
Steven Antonucci
that is very cool.
Josh Bowman
Steve, how did the router vise allow for the eccentric circles? Did you mount the blank off center.....or am I missing something?
Re: How its done
Steve Criscenzo
Josh
I rough turned the outside of the bowl and then attached a 6" diameter glue block to the bottom. I used a face plate centered on the glue block to turn the top. I then mounted the router platform. I used the face plate mounted at a 3/4" offset on the glue block three different times (120 degrees apart) to attach the bowl to the lathe to cut the grooves.
I cut each groove by running the lathe as slow as it would go and advancing the router with the cross feed vise to the desired depth.
The advantage to the router mount with the cross feed vise is that the bowl had to come on and off three times so I could remount the face plate at the next offset. The vise had enough travel to allow me to back off the router enough to remove the faceplate from the head stock without moving the base of the router setup. Therefore, when I remounted the bowl for the next offset groove, I just advanced the vise and everything was still in perfect alignment. Also, the controlled feed and using a router made for clean consistent grooves.
Like I said in the first post, these grooves could have been cut with a parting tool but it would have been difficult to get each one aligned after remounting. I think even a small deviation would have been very obvious.
I have some ideas to push this further and may put an article together if I get good results.
Steve
Steve Criscenzo
Thanks for the lacquer hint John. I did put some CA in the grooves before I poured the Inlace but I ended up overflowing some Inlace onto the rim and that caused some problems. Fortunately, I was able to turn most of the "bleed" off but I was surprised as to how far the black color traveled. Do you just use rattle can lacquer.
Steve
I use a brush and just take care.
Don Leydens
Re: How its done
Don Leydens
Very cool piece, Steve. Reminds me of an article I did a couple issues back in Woodturning Design on multi-axis platters. The fill in idea is great. Gotta try that. Sure saves a lot of sanding in those grooves as well!
Another limitation I had was having to leave the rim basically flat so the depth of the rings were all the same. Can you get past this with your router technique and angle the rim?
Look forward to seeing were else you take this,
Don
Re: How its done
Steve Criscenzo
Hi Don
My apologies. I had the multi axis grooves in the back of my mind for some time. If I had realized the source of the inspiration I sure would have given you credit. I have been working out of town for the last 8 months and I am just getting back to the shop. I have had little time to turn and less to read (or remember what I have read).
I find it so interesting to see how different folks arrive at a common place taking different paths. In reading your article, the screw chuck seems like such a simple solution as compared to my faceplate method.
In response to your question about the angled rim. I am working on a rotating base that will allow the vise to be presented at an angle but I do not think that will allow angled groves on the face of a multi axis turning. If you are using filler however, you can just make the grooves deeper (starting with a flat surface) then fill them and you can create you angle after the fact.
I see you are in Chapel Hill. I am in Durham. Perhaps we can get together and compare notes.
Steve
Three circles and Axminster eccentric
Dave Staeheli
I've done similar things using the Axminster eccentric chuck and a parting tool. Not filling in with Inlace though. Had a brief romance with Inlace, a messy divorce and now prefer a natural lifestyle. Just too plastic for me. Not sure folks appreciate that you are going with three circles. There is an easy technique that uses four off centers and two jaws of a four jaw chuck. Bit of a critique though, can I suggest narrower grooves?
Re: Three circles and Axminster eccentric
Steve Criscenzo
My intent with the router jig was to be able to create enhancements that could not be done with a parting tool (such as stoppped groves ). The eccentric grooves was a test of the router mount. I am thinking of using wood venier in the grooves instead of the inlace.
Steve
Don Leydens
Don Leydens
Sorry for the delay, Steve, I just had 14 teeth removed and dentures put in. Kept me out of circulation for a couple days.
No problem at all about credit. Your way of doing this is quite different (and probably easier in the long run) than mine. The veneer idea you mentioned is very interesting. Please let me know if you try this.
I live in Oxford, NC, and one of the clubs I belong to is the Chapel Hill Woodturners. Maybe you could come to Frank Penta's shop with me and meet the guys and turn with us? We meet at Frank's shop every Thursday and Friday. Tons of fun, great guys and a boat load of ideas flying around.
Just give me a shout and we can set up a date! I'm sure you'd find it interesting.
Don
If you can afford it - Micro Fence
charlie belden
and the Micro Fence precision height adjustabe router device (can't remeber the name of the thing).
With a Micro Fence system for arcs and circles, you can precisely route circles and arcs AND precisely control the depth of cut. There are, of course, othr ways to do this stuff - as you've worked out and tested - but nothing that has the precision of the Micro Fence system. We're talking about the ability to dial things in - in a thousandths of an inch - X, Y AND Z. You really have to play with one to appreciate how precise this system is.
Re: Yea But
Steve Criscenzo
Is there an advantage to having precision to thousands of an inch when working with a material that can move much more than that with temperatures and humidity chnages. (actually it is just too much $$$ and I just have to convince myself that I do not need it)
For what I am doing, I do not see a need to change the height. I do however need the mount to be able to rotate relative to the lathe bed.
Steve
