Oil and Vinegar Spout
Stuart Johnson
Are there any available kits for turning oil and vinegar bottle stopper spouts?
Re: Oil and Vinegar Spout
Oil spout
Dave Staeheli
I've made about four oil spouts. Bought a six-pack of booze spouts from the local home goods store. The tubes that I found have no taper in the tubes and I think that is the key. Took off the chrome ring then straightened the tube. That was the hard part and had some failures where the tube crimped a bit. If I could figure that out reliably I'd probably make more. Then turned a "head" with a hole in the center that would just take the tube with some forcing. The wood "head" is just a little taller than the tube and bevels down to meet the end of the tube. A sharp lip is desireable so the oil cuts off when you stop the flow. There is a vent tube on the silicon plug that I thought would have to have a vent slot carved into the bottom of the "head", but it appears that it is unnessasary. Another problem is that maybe booze bottles have a larger opening than oil bottles and to get it to seat properly I needed to shave off the larger sealing rings. As it is still pretty tight getting it into the oil bottle, I use a bit of silicon glue where the tube seats into the silicon plug, otherwise the tube tends to pull out when removing the spout from the bottle.
If there was a purpose made kit I'd be all over it. But the way I do it now is pretty cheap and not all that hard.
Jim Barbour
Jim Barbour
Packard has a spirit spout that may work http://bit.ly/1eAd7RZ
As does Woodcraft http://bit.ly/1lIFpgZ
I am not sure they are what you have in mind, but ...
Re: Oil and Vinegar Spout *LINK*
Ryan
Did you check out Aftosa ?
http://http://www.aftosa.com/bottle-pourers/
Dennis in Southern Oregon
I have made several pairs very simply without a kit. I mount a suitable piece of wood in a chuck, face off the cork end, and bore a 0.25" diameter hole about 0.5" deep to take a 1.5" piece of hardwood dowel. I then turn the stopper body almost to completion but still solid in the chuck. I then glue the dowel in place and thread on to it an inch long piece of a salvaged plastic wine cork bored end-to-end with a slightly undersize hole so that it grips the dowel. Then I bring up the tailstock live center to hold the cork firmly and turn the plastic cork to the desired diameter and part off it and the dowel using very sharp skew and with light cuts. To finish the body, I grip the dowel stub in a suitable chuck or collet and support it with the tailstock. After applying finish, I glue the cork onto the dowel. Cost? Essentially zero.
Dennis
